06 ccsb chevy onstar and rear dvd not working
Old Dec 20, 2010 | 07:14 PM
shawn57nomad's Avatar
Question 06 ccsb chevy onstar and rear dvd not working
Any Ideas, instantly blows the 15 amp underhood fuse!
Old Dec 20, 2010 | 11:08 PM
TrickyTransAm's Avatar
I would start by checking your connections and wiring. Is it grounded out anywhere?
With the fuse removed, probe one side of the fuse terminal to see which is your battery feed(line) and which is your load (The dvd side)
Check for continuity on the load to ground.
Unplug the DVD player in the rear and check continuity to ground again. With it unplugged, do you still have a ground out condition?
System of elimination.
Old Dec 21, 2010 | 01:17 PM
Thanks for the insight man. I was in the process of elim shortly after I posted, was looking to see if anyone else had experienced this as well. So, I removed fuse, dvd, and unplugged onstar mirror(it's in the circuit with the dvd)... good ground and continuity, was also experiencing the lack of onstar functions as well. Also I left the dvd unhooked, reinstalled the harness to onstar, installed the fuse and the onstar functions worked, no fuse issues. Further I reinstalled the cables to the dvd and no functions on it, but no blown fuse. So, theoretically bad dvd player and the unit smelled toasted too! Any more insight would be great!
Old May 26, 2019 | 03:29 PM
Problem was solved by replacing the screen only as it had a dead short. Used an eBay unit cheap that had a bad disc unit and yanked the screen and swapped. Hope this helped.
thunder550
Oct 8, 2015 04:53 PM
cammed06
Jul 24, 2015 12:09 PM
Ketis
Jul 23, 2015 12:37 PM
signguy62
Jul 16, 2015 05:43 PM
