04 Silverado removing viper alarm/wiring
Old May 30, 2019 | 08:00 PM
JustSurg's Avatar
Default 04 Silverado removing viper alarm/wiring
Hello,
Got this truck on auction and have gotten around to working on it. There was only one key for it, no factory or aftermarket fob.
Pulling all the speaker wires, I came across this viper alarm wired in. My question is, can I just cut this out and use the factory alarm/fob to lock/unlock the doors?
Also, what do I need to do about those wire splices?
Justin
Old May 30, 2019 | 10:00 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Yes, You can.
You will have to pull the cover under the steering column and splice the wires back together where it's tied in.
I believe its a Yellow wire around 10 gauge that they splice into.
I have removed several of them.
Old May 31, 2019 | 06:15 AM
JustSurg's Avatar
Excellent, thanks for the quick response.
Justin
Old May 31, 2019 | 06:42 AM
ILuvJDM's Avatar
If it's a remote start, then they would have cut the yellow wire in half, and that would need to be redone. It is 10ga and you can buy yellow 10ga at autozone by the way.
If it's just an alarm then you can remove those wires and just make sure it's safe and cover with electrical tape. Judging by the "ground wire" in your picture, they are hackjobs so be ready to find some issues when you dig in... Good luck
Old May 31, 2019 | 12:31 PM
NC03GT's Avatar
formerly projectLS10, 2014-09-01
yikes that never would of left our shop looking like that!!! PM me any questions if you run into any issues!
Old May 31, 2019 | 05:25 PM
JustSurg's Avatar
Thank you both for the heads up.
I'll pull that alarm and carpet and get more pictures if you're interested.
Justin
DamnYankee
May 25, 2007 12:37 PM
