SPONSOR PROJECTS, BUILDS, & CUSTOMERS TRUCKS Sponsor's have their own projects and customer's cars they'd like to show off too! Check them out here!
2012 Sierra RCSB 5.3 build thread @ New Era Performance
Old Jul 13, 2013 | 10:45 AM
  #351
Mike @ New Era's Avatar
Banned
Well... yeah lol. But they weren't impressive. I ran 3 11.9's last night, and 1 12.5... I knew 1st gear spun all 4 tires pretty bad on the street, but thought it would be better at the track, but these all terrain tires were much worse than I thought they would be at this power level. My 3 11.9 passes spun all of 1st gear, then most of 2nd gear, then when it caught, it downshifted back to first then spun again etc, I ended up having to let off and back on in all those passes. On the 12.5 pass, I just stayed on it anyway, and sure enough... Bye Bye waterpump pulley again at the 1/8 mile mark, broke the solid weld and ripped it right off. Maybe I should have pinned it, or just went to the electric pump. I guess we will figure this out next and make a permanent solution for this problem.
Old Jul 13, 2013 | 11:09 AM
  #352
KC_kid's Avatar
"At this power level" what do you estimate that is?
Old Jul 13, 2013 | 11:15 AM
  #353
Banned
800+ flywheel hp. I have the Goodyear Wrangler AT/S (All Terrain) tires. The tread is more for an offroad type driving. I am not 100% sure what we are going to do right now, because I am not sure what is in the budget currently. But first we are going to address the waterpump problem. I will update this thread as we move forward.
Old Jul 13, 2013 | 07:53 PM
  #354
ZO6Ted's Avatar
Yeah can't et with no traction lol. Frustrating as hell temporarily. Mph in 1/8 & 1/4?
Old Jul 14, 2013 | 07:31 AM
  #355
rjwz28's Avatar
Man Motor club
Slipping tires save you money somewhere else in the driveline. You could put a set of DRs on there, but you'll find out really quickly where your next weak point is...
Old Jul 14, 2013 | 09:16 AM
  #356
Gadgetized's Avatar
Here is Mike's Camaro VS his truck. This was the one where it was bucking pretty good. Still an impressive run. The truck sounds like a jet engine going down the track.
2010 NewEra Camaro SS vs NewEra GMC Sierra Pick up - YouTube
Old Jul 14, 2013 | 05:26 PM
  #357
fortplainman's Avatar
once the truck gets settled down, the truck will run faster than the camaro lol.
Old Jul 17, 2013 | 11:04 AM
  #358
Banned
Well, here is an update. We found this aftermarket water pump by PRW for the trucks, it is higher flowing and frees up some load in doing so. But more importantly, the pressed on hub is 2 inches long, and it has a billet pulley that bolts onto the hub with 4 bolts. It is made by PRW and costs $380, this should (hopefully) do ths job now, and no more slinging water pump pulleys...
Old Jul 17, 2013 | 11:20 AM
  #359
okieraptor's Avatar
Does The New One Have A Key Machined In It?
Old Jul 17, 2013 | 11:22 AM
  #360
Banned
No, it is just a 4 bolt hub. We'll find out if it works...
