Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
need help with torque specs
Old Nov 30, 2006 | 08:02 PM
nightrunner's Avatar
Mr. Obvious
Default need help with torque specs
i would like the torque specs for the water pump bolts for a 01 4.8
do you guys think i need to use a torque wrench on them or just hand-ratchet(1/2") tight
it is all appreciated
also any benefit from going to a 180 degree tstat ( stock is 187 )
and are there any mods needed to mount a 34" radiator in my truck
thanks for the help
Old Nov 30, 2006 | 08:38 PM
SSlow 4.8's Avatar
damnit.. wish i was at my house bc i have the haynes manual for the 01 4.8, 5.3 and 6.0... but idk about the torque specs
check this out for water pump specs.. its for an ls1.. but probably the same >>> http://www.ls1howto.com/index.php?category=1
as far as the stock themro goes.. i thought it was 195, i could be wrong tho... the 180 would probably help somewhat im sure
heres some info on that >>> https://www.performancetrucks.net/fo...+radiator+swap
I think the radiator swap is a direct replacement.. hoses and all
ya im bored, hope this helps
Old Nov 30, 2006 | 08:49 PM
thunder550's Avatar
High on diesel fumes
Old Nov 30, 2006 | 08:54 PM
SSlow 4.8's Avatar
beat you to it... hoe
Old Nov 30, 2006 | 08:59 PM
Colby 04's Avatar
huh?
Old Nov 30, 2006 | 09:03 PM
thunder550's Avatar
Hahaha I didn't see your link up there. OOOOOPS!!
Old Nov 30, 2006 | 09:06 PM
Mr. Obvious
on the stock thermo setting 187 is what is listed as stock on the autozone computer
take that for what it is worth
Old Nov 30, 2006 | 09:08 PM
Mr. Obvious
thanks guys for the help
does anybody think i will be ok with just normal ratchet tightenin gor do i NEED a torque wrench ill have to buy one or rent/borrow one from somewhere
Old Nov 30, 2006 | 09:13 PM
SSlow 4.8's Avatar
well its only saying 11 ft lbs or so.. so i think you'll be okay with whatever
Old Nov 30, 2006 | 09:18 PM
Mr. Obvious
its saying 11 ft.lbs first time around and then 22ft. lbs. the second/last time around
anybody know what the water pump cover bolts are my pump didnt have a cover over it
