Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
HELP....no oil pressure
Old Sep 26, 2007 | 12:31 PM
2k5Squirrel's Avatar
14 Second Truck Club
Default HELP....no oil pressure
4 times today while trying to start my truck i had NO oil pressure. once i even checked it with the Interceptor and that read 1. the last time i had to kill it 3 times before it would read any oil pressure. i also did one WOT and it read 98 on the Interceptor.....Help
Old Sep 26, 2007 | 01:25 PM
slowec's Avatar
get a manual gauge for testing before you crank it again!
Old Sep 26, 2007 | 02:05 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
How many seconds has it ran without oil pressure? Swap out your oil filter, and also check with a mechanical gauge. If all else fails pull the pan and make sure the pick up tube is still attached to the pump, if it is pull the front cover and replace the oil pump. A small spec of dirt can wedge the pressure piston in the oil pump and you will lose oil pressure. Ask me how I know
Old Sep 26, 2007 | 02:12 PM
maybe 5 each time. should i just go ahead and get a high volume/ported oil pump? got a parts list? i'm going to have to order everything first, make sure i get it all and then do it. it also takes about a week to get parts over here.
Old Sep 26, 2007 | 02:21 PM
1slow01Z71's Avatar
Depends on how far you want to go to diagnose the problem. If you revved it all the way and didnt get any oil pressure then it could be, debris in the piston, pickup tube popped off, o-ring pinched or a bad/clogged oil filter. I would just get a new pump and shim the spring a little and run with it. I ported mine and added a small shim and Im at barely under 80 while cruising around with 40 weight oil. If you are going to do a cam swap now is the time since you will already be there.
Old Sep 26, 2007 | 02:34 PM
RandomHero's Avatar
Ask me how I know
How do you know?
Old Sep 26, 2007 | 02:55 PM
i never revved it. it started dinging at me and said "low oil pressure" so i turned it off. the oil filter i ordered from the States should be here this week. was going to change the oil this weekend. 918s should be here this week too. was still deciding on a cam but i goes i'll just go ahead and bite the bullet and order one tomorrow. might as well get me parts list going, lol
any ideas on oil pump? just get a ported/high volume one? i guess i'll start searching threads for all the other chit needed for the breakdown.
Old Sep 26, 2007 | 03:06 PM
alright...just went out and tried it again. it's about 45 outside, said "low oil pressure" for about 2 secs and then it was fine. cold start idle @ about 750 RPMs and oil pressure was reading 40-43 on the interceptor. oil level is fine. do you think a sensor could be going bad? wouldn't the Interceptor DTC function pick up on that?
Old Sep 26, 2007 | 03:28 PM
1slow01Z71's Avatar
If you lose oil pressure again start it up and rev it to around 2K, just bump the throttle, if it doesnt rise then you may have a bad sensor or screwed up pump.
Old Sep 27, 2007 | 08:12 AM
seems to be OK today. did it for a few seconds on the initial start-up this morning. but after that it's been fine.
Texas5.3_1251
Mar 5, 2016 08:10 PM
69z-28
Sep 21, 2015 07:31 AM
Go5.3tt06
Sep 14, 2015 02:11 PM
Brandonlflr12
Sep 8, 2015 09:01 PM
Boyes50
Sep 8, 2015 12:06 PM
