Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
Habit I'd like to BREAK!!!!!
Old Nov 24, 2008 | 08:01 PM
KySilverado's Avatar
Hope its not serious. Those kinda things ruin track days.
Old Nov 24, 2008 | 11:29 PM
454navyss's Avatar
hope its nothing major, bent pushrod or something, 13.6 is a decent time for a brick
did you look at the bottom of the valve cover to see if it looked like anything was hitting it?
Old Nov 25, 2008 | 04:24 AM
magnetized's Avatar
That sucks, hope it's nothing major
Old Nov 25, 2008 | 05:44 AM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
454... Valve cover is fine. Rained yesterday. No garage here (stupid carport). Hope to have some time to start pulling head (driver side) this evening. Of course, will post pics of findings. Got a audio/video clip uploaded. Will post this morning.
*edit*
Video clip of tapping/knocking added to first post. Let the speculating begin!
Old Nov 25, 2008 | 07:29 AM
ChevyTruck's Avatar
something else
Sounds like a diesel.
Sorry to hear about you bad luck at the track.
Old Nov 25, 2008 | 12:14 PM
Tootall's Avatar
rod bearing . . . RPM dependent
Old Nov 25, 2008 | 12:38 PM
My bet is rod bearing also.
Old Nov 25, 2008 | 12:49 PM
95ImpSS's Avatar
Any 6.0L's for sale?!?!
Old Nov 25, 2008 | 12:53 PM
RandomHero's Avatar
Man, that's really depressing that you've had so many problems. Do you keep fixing old parts or replacing with new stuff? It almost seems like there is a bigger problem behind all your issues.
Old Nov 25, 2008 | 08:08 PM
Truckshop's Avatar
quit reving it and pull the pan. you may get by with rod bearings and some new rod bolts. we all you know what the underside of that truck looks like. the jackstands should still have there marks on the ground. it could be worse you could see inside the motor from the driver side wheel. hell, call matt. i hear he has gotten quick at swapping engines out. you may wanna check for missing bolts after he is done though.
