Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
Any hope for the 13's
Old Aug 14, 2005 | 10:19 PM
white1's Avatar
Default Any hope for the 13's
I really want to break into the 13's for the shoot out. Anyone think its possible if I get some smaller tires? Mods in sig.
Old Aug 14, 2005 | 11:34 PM
SSlow 4.8's Avatar
What will you have for the shootout.. i see in your sig that you said coming soon to be a stall and a bigger cam... is that going to happen for the shootout, or no?
Old Aug 15, 2005 | 07:01 AM
white1's Avatar
Should be in. Im planning for the 218/224 cam a 2800 or 3000 stall, shift kit, and some smaller tires. The 32" buckshots just aren't working. Probably get some 2wd sized tires not sure what size yet. Maybe 285/60 or smaller
Old Aug 15, 2005 | 07:37 AM
goshawk23's Avatar
Truck addict
well, if you go with a higher stall tq verter, plan on getting some sort of drag radial in the 26" area. going from 31" tires to dr's i dropped my et by over 2 tenths.. this was on the stock stall. also, with the stall your gonna need the extra traction that a dr will give you vs the stock size tire. not sure how buckshots hook. not sure if you'll hit 13's but it could be close.
Old Aug 15, 2005 | 08:01 AM
white1's Avatar
I can always use 4 hi if my traction issues get too bad.
Old Aug 15, 2005 | 08:39 AM
goshawk23's Avatar
Truck addict
yea, i forgot you were 4wd. try to find you a set of 26" to 28" tall tires. that should help with weight as well as gearing.
Old Aug 15, 2005 | 09:05 AM
SSlow 4.8's Avatar
Ya i think it'll be close... if you get into the 13's or not. Where are you located? I have some 26.5" dr's that i'm not using bc my tranny is being rebuilt... if your near North georgia than i'd say you can use them.
Old Aug 15, 2005 | 09:22 AM
white1's Avatar
I'm in south La. Thanks though I really want to try some out.
Old Aug 15, 2005 | 09:41 AM
goshawk23's Avatar
Truck addict
if you go to NPR anything is possible. low elevation good da's.
Old Aug 15, 2005 | 11:32 AM
white1's Avatar
I'm looking into some spray too, but really want to be in the 13's befors I spray. 12 sec 4x4 would make for some impressive rooster tails
