Silverado SS, Joe Gibbs Editions, SSR Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
consuming oil
Old Oct 19, 2007 | 04:41 PM
one fast ss's Avatar
Default consuming oil
well i been driving my truck for a while and i put castrol syntec motor oil in it. if runs fine but i went to check the oil today and it seem that iam useing oil. i duno what could be causing this. its a bran new engine (408). is there any additives to stop this? or help it?
Old Oct 19, 2007 | 05:45 PM
mwalls54's Avatar
Need More N2O Mod
how much oil are you burning?
Old Oct 19, 2007 | 07:08 PM
ummmm well its 2000 more km till my next oil change and im down about 1-2 quarts
Old Oct 19, 2007 | 07:10 PM
TXsilverado's Avatar
big cubed motors use more oil get used to it. its never guna be like your 4.8/5.3 that consumed 0 oil. i consume about 3/4 quart every 1k miles and theres absolutely nothing wrong with my motor(besides a shitty designed pcv system)
Old Oct 19, 2007 | 07:18 PM
Quik's Avatar
5 year bitches!
your motor shouldnt be consuming any oil if built properly. your ring tolerances could be the reason. also what are you running for PCV or are you using breathers? i would ditch any PCV that you might be using and run two breathers
if you continue to use oil after swapping to breathers then you have a choice to make. continue to run the truck and add oil or pull motor out and rebuild it.
my 408 had no oil consumption issues
Old Oct 19, 2007 | 07:20 PM
tarinitup's Avatar
9 Second Truck Club
I went from 5w30 to 10w30 and it has helped out with consumption and noise.
Old Oct 19, 2007 | 07:26 PM
well iam useing a sythetic...im wondering if i went to a conventional oil for a bit like castrol gtx until the enigne if completely broken in. i'll try the breathers anyway. i dont know why it would use oil anyway becasue is used the best parts i could find..li used the plasma rings.
Old Oct 19, 2007 | 07:45 PM
Quik's Avatar
5 year bitches!
i used 20w50. alot of strokers recomend that oil. i wouldnt run syn till about 2k to 3k in miles. using it during breakin isnt the best idea around
best of best parts dont mean nothing if it was installed wrong
Old Oct 19, 2007 | 08:23 PM
what type of oil you running? like the manufacture. also who would i call to get an idea on what oil i should switch to for my stroker
Old Oct 19, 2007 | 08:25 PM
Quik's Avatar
5 year bitches!
i had ran valovine 20w50. once it broke it i was going to run RP 20w50. but if your comsuming oil heavy weight is abandaid.
