ANyone have 1/4 mile times on a regency rst 4.8L 5 speed?
#21
If the quick connect is at your master, the end you need to drill at your slave. That's where mine was. I had to knock out the roll pin that held it in the slave and then did the drill mod. So if you have the old setup there is hope, but it requires you to drop the tranny to remove the slave.
maybe one day, if my hydraulics ever go out, i'll replace it all with newer stuff & drill the line out.
#22
you sure? that sounds like the new setup. the old style (99-01) has the quick-connect at the slave & the roll pin at the master. i tried to do mine (a 99) a couple years ago while the engine was out. when i got to looking at it, it's a crazy line that's half molded plastic & half flexible hose, and when i disconnected it from the master & tried to find the restriction, it felt like it was open all the way to the plastic half.
#23
no coupling - just braided with a plastic line molded to the end of it. believe me - i tried to find a way to do this mod. us old truck guys are just SOL
Choda
Jan 22, 2026 02:03 PM
