Its a return back to the reservoir. If you have a hydroboost power steering pump there is a fitting directly on the side, if not, you need to Tee into the return line.
You sir, are wrong. The part pictured is a master cylinder. Not a booster.
Yea ****, I meant cylinder. I must have a hard time doing two things at once. So back to my intent was this master cylinder will bolt to a gm booster if it so happens to be the correct bolt pattern that wilwood says it is.
This afternoon I picked up a hydroboost with master cylinder and brake pedal from a 2003 Yukom Denali. It looks to have an auto brake setup on it. I'm thinking this brake pedal won't work and that the master cylinder will at least need a different reservoir.
This is on the master cylinder
This is my truck. This is my truck. This is my truck.
