Hydroboost Conversion Install
Old Jan 24, 2018 | 12:09 PM
  #241
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by adriver
Thats awesome, and so quick. Thank you. I am ready to give it a try and see what happens.
Look in this thread too. It shows the location that needs to be drilled.
https://www.performancetrucks.net/fo...w-pics-441147/
Old Jan 26, 2018 | 08:22 AM
  #242
About20ninj45's Avatar
Default Dumb Question
Where does this line go/attach to?
Old Jan 26, 2018 | 01:59 PM
  #243
Atomic's Avatar
I have a gauge for that
Its a return back to the reservoir. If you have a hydroboost power steering pump there is a fitting directly on the side, if not, you need to Tee into the return line.
Old May 22, 2019 | 12:23 PM
  #244
707sendit's Avatar
Default Willwood
I think this will work for an aftermarket booster
Correct me if I’m wrong
Old May 22, 2019 | 09:20 PM
  #245
1FastBrick's Avatar
You sir, are wrong. The part pictured is a master cylinder. Not a booster.
Old May 22, 2019 | 10:27 PM
  #246
707sendit's Avatar
Yea ****, I meant cylinder. I must have a hard time doing two things at once. So back to my intent was this master cylinder will bolt to a gm booster if it so happens to be the correct bolt pattern that wilwood says it is.
Old Jan 26, 2022 | 02:27 PM
  #247
blsnelling's Avatar
Do I need to replace the master cylinder or will my vacuum one work properly?
Old Jan 26, 2022 | 03:48 PM
  #248
BigKID's Avatar
Several in this thread swapped over their vacuum master to avoid bleeding the brakes with no issues.
Old Jan 27, 2022 | 08:22 PM
  #249
blsnelling's Avatar
This afternoon I picked up a hydroboost with master cylinder and brake pedal from a 2003 Yukom Denali. It looks to have an auto brake setup on it. I'm thinking this brake pedal won't work and that the master cylinder will at least need a different reservoir.
This is on the master cylinder
This is my truck.
This is my truck.
This is my truck.
Old Jan 27, 2022 | 08:29 PM
  #250
blsnelling's Avatar
2001 Reservoir 2001 Reservoir
