will this work or not?
Old Dec 30, 2009 | 01:51 PM
slownlow4.8's Avatar
Default will this work or not?
im wanting to run 295/40 on the back of my truck with a 7" drop, i wondering if the tire will fit with the wheel offset. i plan on rolling the lip.
the specs on the wheels are
wheels size 20x8.5
rear spacing 5.0"
offset +6mm
Old Dec 30, 2009 | 02:19 PM
VMaxAZ's Avatar
Most everything I've heard is you will need +30mm offset to tuck
Old Dec 30, 2009 | 09:59 PM
that what i though cause all of the guys running 305 or 315 have +31mm
Old Dec 30, 2009 | 10:49 PM
VMaxAZ's Avatar
I'm currently running a 305/40/22 on a 22x9 rim with +25 offset and I rubbed on the front inner fendor plastic. I ended up molding the plastic to clear. In the future, I'm going to get wheels with a higher offset.
Old Dec 30, 2009 | 10:53 PM
SuperchargedSS's Avatar
yes, it will fit, if you shorten your rear end.
Backspacing being 5" and the wheel being 8.5" wide, you are at a 3.5" lip. That coupled with a 295/40, I don't think its gonna make it?
For example, I have 22x10 with 7" Backspacing and my rear tires just barely clear the fender. I am only dropped 6" and running a 285/40.
Old Dec 30, 2009 | 11:17 PM
ext 4.8 pewter's Avatar
u might want to go with maybe a 275 40 or trim the fender lining
Old Dec 30, 2009 | 11:47 PM
007gmc's Avatar
i have a 275/40/20 on a 20X8.5 +12 with a 6" drop and it cut my tires all up until i rolled the fenders on the bedsides. now it clears but there is no room for any bigger tire or a lower offset wheel
Old Dec 31, 2009 | 12:16 AM
1quickRST's Avatar
I run a 295/45 on a 20 x 8.5 with +20 backspacing and there is no way I could ever do a 7inch drop on that set up. It is pretty much flush with the wheel well. If you had the skills to flare the fender, it might fit then, but its gonna have to be flared quite a bit to make it work.
Old Jan 2, 2010 | 12:35 AM
i was reading up on the offset and everthing and i'm wondering in i can go any lower. even with a narrow tire.
Old Jan 2, 2010 | 03:50 PM
dlt76028's Avatar
i have a 6" drop in the back and i'm thinking about 295/40/20 also. i have centerline 20x8 that are 5" backspacing and +12mm offset. it looks close, right now i have 275/45 with no problems.
shawn96gmc
May 17, 2016 04:15 PM
Stainless Works
Apr 10, 2016 04:34 PM
Stainless Works
Aug 4, 2015 12:56 PM
atxlt
Jul 20, 2015 11:06 PM
Nimoryan
Jul 5, 2015 03:50 PM
