wheel spacer on one side
Old Jan 7, 2018 | 09:45 AM
Albertachevy's Avatar
Default wheel spacer on one side
has anybody ever ran a wheel spacer on one side only? I have a 14 bolt swap that the perches got welded with the whole housing shifted to the passenger side.
Old Jan 7, 2018 | 09:50 PM
Duntov1967's Avatar
I would fix the perches especially now that the centerline of the driveshaft is off.
Old Jan 8, 2018 | 10:40 AM
arthursc2's Avatar
Ah man what a fucked up problem to have. Guess a tape measure was just too expensive for your welder?
I agree with man ^. Fixing the perches isnt terribly hard, and if a tape measure was too expensive, I imagine the welds arent that great either. Safer/better/smarter to get the perches fixed. Not the cheapest, but we arent in this game to save money are we?
Old Jan 8, 2018 | 10:46 AM
TXsilverado's Avatar
it doesn't hurt for your driveshaft to sit off center. it's probably actually better for your u-joints since they will get more movement/lubrication, but I agree with the rest. Fix it the right way.
Old Jan 8, 2018 | 11:05 AM
kbracing96's Avatar
To answer the OP question, yes it's just fine to run a wheel spacer on one side as long as your studs are long enough.
Old Jan 8, 2018 | 05:27 PM
Duntov1967's Avatar
More elaboration is needed as to the down side. When creating a horizontal angle in addition to a vertical ange, you now have compound angles. The has two noteable effect. Racers change vertical pinion angle to tune their suspension. It will either hook up better or worse. Having an angle on the horizontal will have an effect from side to side that can only be detrimental. Additionally there would be more chance of vibration. This video show what goes on when changing angles albeit exagerated for demontration purposes. Now compound that by have the angle offset horizontally and you have a compound issue.
Old Jan 10, 2018 | 04:35 PM
yea im not happy about it. it didn't seem quite right after it was welded but I couldn't pinpoint the problem without having much to go off of in an empty housing. now its sandblasted and painted....
Old Jan 10, 2018 | 04:57 PM
someotherguy's Avatar
https://www.youtube.com/watch?v=gmV4qwLfOMY
Man, excellent video that shows the issues with not only bad angles but also with improper phasing. I wish I'd had that video handy in the past, explaining pinion angle issues to people with dropped trucks.
Richard
Blackdog76
Feb 16, 2022 12:22 PM
Serrano454
Aug 2, 2012 03:51 PM
getchusum99
Sep 25, 2011 05:53 PM
ohohsilverado
Oct 10, 2004 11:21 PM
