Whats under side trim?
Old May 13, 2015 | 10:29 PM
dantheman1540's Avatar
Default Whats under side trim?
Its an 05 RCSM and on the doors its got the plastic trim strip with a little bit of chrome on it and I would like to ether remove it completely or paint the chrome color match. But I was wondering what is holding it on before I go tearing it off. is it just double sided tape? or some of those plastic push rivets and some holes in the sheet metal?
Old May 13, 2015 | 10:37 PM
FFDP's Avatar
Should be just the 3M tape stuff.
All there was one my 06 sierra.
Old May 14, 2015 | 10:27 AM
thunder550's Avatar
High on diesel fumes
No holes, just tape as said above. You should be able to get in there and pull the trim off, then use something like a 3M magic eraser wheel to get the tape residue off.
Old May 14, 2015 | 03:48 PM
Awesome they will be ripped off tonight probably!
Thanks for the help!
Old May 14, 2015 | 04:02 PM
FFDP's Avatar
Use a hair dryer/heat gun to warm up the tape first, makes everything quicker.
Old May 14, 2015 | 04:13 PM
GMCtrk's Avatar
heat gun, 3m eraser wheel and goo-gone.
Old May 14, 2015 | 07:19 PM
trxmxzx's Avatar
13 Second Truck Club
Hopefully your truck wasn't repainted- it happened to a old buddy they used that as a tape line and it was two different colors
Old Jun 2, 2015 | 01:57 AM
jakenm's Avatar
I used heat gun and fishing line before. To remove the adhesive residue, I only used wd40 and it worked great.
Old Jun 2, 2015 | 06:20 PM
krainium's Avatar
This happened to me ended up having the door resprayed
Old Jun 3, 2015 | 10:11 PM
Well I started one side with a razor and messed the paint up pretty good then got smart and got a magic eraser wheel! its the best thing ever!!! thank you for the suggestion!
