Toyo open country
Old Jan 31, 2012 | 02:33 AM
kr1s's Avatar
Default Toyo open country
Should i get the open country A/T or H/T
any opinions on these?
I'd probably run like a 265-75-16 or 17 around that size
I don't wanna run a 285 again
OPEN COUNTRY A/T | All-Terrain Tires for Pickups and SUVs | Toyo Tires
OPEN COUNTRY H/T | Toyo Tires
Old Jan 31, 2012 | 02:54 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
What kind of driving do you do mostly? The HT will have better wet road grip, will be quieter, and has less rolling resistance. That will net you better fuel economy, and a longer lasting tire. The AT will work well on wet & dry roads, but will have better grip off-road. So if you need an all-terrain tire, it will better suit your needs, at a trade-off.
Also, if you drive on alot of gravel roads, the AT will be more chip-resistant, and the tread will be more durable. Mostly it just depends on your needs & expectations from the tire.
Old Jan 31, 2012 | 03:07 AM
kr1s's Avatar
HT would be fine, i don't go off on my off road adventures with the GF anymore so i'm fine I think the HT would be fine, I want something with around a 112-118 speed rating
And pretty much just going to the beach and highway/street driving
Old Jan 31, 2012 | 03:10 AM
kr1s's Avatar
maybe the A/t since i'm going with a 3in lift on my truck... hmmmm i need to look around more and do more research
Old Jan 31, 2012 | 05:22 AM
Zeke2007's Avatar
I had the ATs in a 285/75/16. Great riding tire not much howl.. good off road. Little pricey. But a good all around tire one of the best I've had for sure
Old Jan 31, 2012 | 05:33 PM
kr1s's Avatar
Thanks zeke
I think those are the ones ill get, did you ever take them to the track?
Old Jan 31, 2012 | 05:56 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Loved my toyo mts on my Dmax, they didn't do too well at the track though but that could've been because of the 800rwtq
Old Jan 31, 2012 | 06:12 PM
Alpinestar's Avatar
I think my brother got 40K miles out of his toyo A/T's. My last set of tires I went with the cooper zeon ltz which are a similar tread pattern for about $50 less per tire. IDK their speed rating but I have had them up to ~120 a few times
SloSVO
Nov 22, 2020 07:34 PM
00loudchevy
Dec 3, 2015 05:54 PM
JordanH
Oct 3, 2015 03:59 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
dantheman1540
14
Sep 28, 2015 09:22 PM
