Suncoast Creations Hood
Does anyone have one? I was wondering how well they fit and hold up.They have one fof 99-2004 that looks bad *** on the GMCs.Also would i need there ramair kit or would a K&N fipk work with it ?
Originally Posted by tbyrne
Just put one on my GMC truck. Had it modified to remove the heat extractors. It looks schweettt!!!
The heat extractor option is worth it (they cut open the cowls to help vent heat, then mold in screens so you don't suck in leaves/etc.), but avoid the Ram Air setup - it's designed to route air into the OEM airbox with a drop-in filter, if you're using an FIPK or similar aftermarket intake then the Suncoast kit won't work.
carid
Oct 28, 2015 08:24 AM
