Removing Yellow Road Paint??????
Old May 21, 2006 | 09:43 AM
dirtyratt's Avatar
If your truck has factory paint use a good paint thinner it will take it right off.factory paint is baked on and the thinner wont hurt the paint at all and then just rewax or what ever you use. good luck
Old May 26, 2006 | 12:00 PM
allenmehrer's Avatar
i'd try to work a clay bar into the equation some how, maybe after you get the thick stuff off with a credit card
Old May 26, 2006 | 08:50 PM
03sierraslt's Avatar
That thought scares me, I have a couple spots of road paint as well. Might try the credit card thing but I worry about paint thinner.
Old May 26, 2006 | 10:37 PM
BlackGMC's Avatar
Resident Retard
Originally Posted by TouchOfEvil04
Clay bar?
I say clay, but then again never had that stuff on my paint before.
Old May 26, 2006 | 11:46 PM
Xtreme402's Avatar
Don't use laquer thinner,acetone,or any other harsh solvent. I recommend using denatured alcohol. We use it at the hanger to remove overspray and such from the lexan and plexiglass windows and windshields. I have used it before on factory finishes on cars and seems to be the safest way to get the job done. Use a soft detail cloth that won't scratch the finish and above all else take it slow so you dont damage the clear. Don't worry about the alcohol it won't hurt anything.
Old Jun 6, 2006 | 03:40 PM
Beastofa327's Avatar
Originally Posted by stone150
clay, goo gone, and fingernails atleast that's what i did, also tried wd40 didn't work well for me
yeah goo gone or goof off or I've used carb and choke cleaner(disclaimer don't use it if your worried about your paint rubbing off) I used it and my clearcoat didn't come off and it worked great I've used it to remove the double sided tape under the molding and badges.
Old Jun 6, 2006 | 09:39 PM
ballagh's Avatar
Here in Iowa we use Diesel Fuel to remove tar and paint soaked in a sponge, then wash! Works great
Old Jun 8, 2006 | 09:37 PM
smoke468's Avatar
Default yellow paint removal
I worked @ a detail shop for 6 years. Needless to say I ran across this problem more than once. What we used was oven cleaner. The trick is to not let it sit too long, but if it doesn't sit long enough it won't be as effective. Start by scraping off what you can with a plastic scraper. Then spray it on the bottom lip of the panel,(to make sure it won't hurt your paint) let it sit, then hit it with a decent pressure washer. With whatever is left on, use a wet rag with laquer thinner to remove the rest. We used this method with success. You will most likely have to buff the affected area to clean up the minor scratches. Good luck and hope it works out for you.
Pontiac Derek
Sep 19, 2015 01:49 PM
Pontiac Derek
Sep 18, 2015 09:02 AM
iregret
Sep 10, 2015 09:00 PM
lxcoupe
Sep 2, 2015 12:58 AM
jtphelps289
Sep 1, 2015 08:58 PM
