Removing side moldings
Old Feb 22, 2008 | 01:54 PM
MS3Z's Avatar
Default Removing side moldings
The clear or whatever is starting to peel on my side moldings. How do I just take them off.
Old Feb 22, 2008 | 01:57 PM
sbw9056's Avatar
I think if you do a search you can find all the info you need. Try the show and shine section.
Old Feb 22, 2008 | 02:05 PM
MS3Z's Avatar
Yeah I didn't find anything real useful.
Old Feb 22, 2008 | 02:06 PM
MS3Z's Avatar
How long do you have to heat it up with a heat gun before you can go tugging on it?
Old Feb 22, 2008 | 02:08 PM
sbw9056's Avatar
When I removed my mouldings, I used some braided nylon fishing line to get behind the mouldings and saw through the double sided tape holding them on. Then I rubbed off the remainder of the tape and cleaned up the adhesive residue with lacquer thinner.
Old Feb 22, 2008 | 02:10 PM
sbw9056's Avatar
I did not use a heat gun. I took mine off in the summer and the heat from the sun was enough.
Old Feb 22, 2008 | 02:31 PM
MS3Z's Avatar
Yeah but its the middle of winter here and I'm having the truck polished and waxed tomorrow so I thought now would be a good time to do it.
MS3Z's Avatar
I'll use the heat gun on them then I'll use the fishing line.
Old Feb 22, 2008 | 02:34 PM
LowBlack99's Avatar
guitar string and bondo applicators work well also. Don't get crazy hot with the heat gun either, if it's to hot to touch with you hand then you got it to hot. Take your time to prevent damage to the paint.
zblee
63
Jun 10, 2023 01:25 PM
GXPJAY
Feb 13, 2022 08:15 AM
signguy62
Jul 27, 2015 03:42 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
