Painting Questions?
Old Jul 4, 2005 | 08:03 PM
Does that piece come off, what do you guys suggest about me doing it myself or having someone do it, never done anything like this before and dont want to screw it up but then again i want to start doing stuff to the truck for myself?
Old Jul 5, 2005 | 05:27 PM
wes00silverado's Avatar
Yeah I'm in the same boat as you are. Never done it before but really want to learn how. If I do it right then I can do my doorhandles and tailgate handle.
Old Jul 5, 2005 | 06:23 PM
Well let me know how yours comes out can you do the handles the same way?
Old Jul 14, 2005 | 06:34 AM
Beastofa327's Avatar
To take off the lower valance just pop the anchor rivits with a flat head screw driver than from the top pull out with needle nose plyers to paint, if its textured don't worry about sanding, thers a paint adhesive to help it adhear to the paint but I don't remember whats it's called use that than prime it lay it on thick than sand it down with 400 grit till smooth than paint to the color you want, only do this next step if your doing this for show you than sand the paint with 2000 grit than 3000 than use a fine cut compound to gloss shine and than shoot with clear coat to protect the paint 2 or 3 coats should be fine...as for door and tailgate handles you can do the same. If not for show, just prime paint clearcoat and your done.
Old Jul 14, 2005 | 07:05 AM
Fogle07's Avatar
sand the thing down almost smooth then put some primer on it. sand the primer with 320 till its smooth, spray sealer on it, then 2-3 coats of base, then 2 coats of clear. if your good you dont have to sand it down and buff it. it looks way better smooth than with the texture in it. thats just my opinion.
Rafe19
Oct 18, 2016 12:27 AM
Lamartian92
Sep 9, 2015 04:17 PM
wrb002
Aug 25, 2015 03:56 PM
LaBlackIce
Aug 15, 2015 10:55 AM
USMCvet0311
Aug 1, 2015 07:45 AM
