painting the interior questions
Old Aug 11, 2007 | 08:55 PM
2004SSS's Avatar
Default painting the interior questions
i am wondering how some of you painted the soft parts, like the interior door arm rest/handles , grab handles on the roof and door panels. most of the parts are hard plastic whihc will be easy , btu the soft parts looks like they need glass or something to make them firm so the paint wont crack. any ideas??
Old Aug 11, 2007 | 09:00 PM
nightrunner's Avatar
Mr. Obvious
i think you dye the soft parts
Old Aug 11, 2007 | 09:02 PM
2004SSS's Avatar
but would the die shine like paint though?
Old Aug 11, 2007 | 09:08 PM
Mr. Obvious
doubt it
Old Aug 11, 2007 | 09:27 PM
RandomHero's Avatar
I've seen it done before. I'm pretty sure you have to use a hardener. I believe it's like a vinyl hardener or something to that tune.
Old Aug 11, 2007 | 11:51 PM
StrokerAce03's Avatar
The vinyl used on the oh **** handle and the armrests will get a spongy feel when sanded well; then all is needed is some resin and hardener and you're good to go. I guess you could mat it or use kitty hair but I've seen it done the way I described and it seems to work well as it gives you a good surface to adhere the resin to.
Or you can scuff and then prime and paint like normal if you use a lot of flex additive. Never used any flex agent so I can't comment on that
Old Aug 12, 2007 | 11:08 AM
2004SSS's Avatar
really so no mat was needed just resin? i wouldnt thin the structure would be enough, how many lairs did you use?
Old Aug 12, 2007 | 11:30 AM
moregrip's Avatar
what a rush!
use SEM products
http://www.sem.ws/category.php?category_id=55
http://www.sem.ws/product.php?product_id=242
Old Aug 12, 2007 | 11:40 AM
2004SSS's Avatar
never seen that befoe have you tried it ? imo it doesent look like it will have the gloss i need.
Old Aug 12, 2007 | 12:11 PM
SEM will just look factory just different colors, not what you are looking for
thunder550
Oct 8, 2015 04:53 PM
spiritfish
Aug 23, 2015 09:58 PM
Bluchevypick
Aug 18, 2015 09:11 AM
thewrx
Aug 12, 2015 08:28 PM
USMCvet0311
Aug 1, 2015 07:45 AM
