Lowering questions from a newby!
Old Mar 22, 2011 | 04:53 PM
EB001's Avatar
Registered User
Default Lowering questions from a newby!
i have an 02 silverado i bought from my uncle its a rcsb. he put a leveling kit on it before i bought it and im not sure what he did exactly but i want to drop it about 1" in the front and rear so could i just do 1" hangers and 1" drop shackles and be done?
what else would i need, help is much appreciated
Old Mar 22, 2011 | 05:23 PM
Static54's Avatar
Im thinking this question would go in "GM Drivetrain & Suspension" forum.
Is the truck 2wd?
Old Mar 22, 2011 | 05:52 PM
Beatdown Z's Avatar
Laid Back
Do you have a pic of how it sits now? One inch will hardly make a difference...
Old Mar 22, 2011 | 06:35 PM
little03chevy's Avatar
^^^ with him!
Old Mar 22, 2011 | 06:58 PM
Nuclear Endless's Avatar
^ x3, 1 inch is nothing... I'm not even really all for gettin the 2 in shackles cuz its only barely noticeable...
To answer your question, the leveling kit should have raised the front up to be even with the back, to fix the factory forward pitch
Old Mar 22, 2011 | 07:19 PM
454navyss's Avatar
hangers and shackles are both on the rear suspension....and hangers are a pain in the *** to do so i would not recommend them. need to know what your uncle did to lower the back though, he may have already done shackles. in the front you can do spindles, lower control arms or coil springs with springs being the cheapest. you will be wasting your time doing 1" all the way around, 2" will be a better way to spend your time and money.
Old Mar 23, 2011 | 12:12 AM
EB001's Avatar
Registered User
yeah i talked to him today and he said the same thing you all did, but also i run 275/55/20 tires on it so he said dropping it any lower was going to be very very close on those tires so i probably am just going to let her be for now
thanks for all the replies though. like i said im new to this site and new to the custom truck world and this site has been a huge help in things.
Old Mar 23, 2011 | 07:40 PM
Beatdown Z's Avatar
Laid Back
I'm currently running those same size tires with a 2/4 drop and they do rub on big bumps. They would be fine if you just tweaked the fenders a little bit.
GXPJAY
Feb 13, 2022 08:15 AM
GXPJAY
Nov 5, 2015 06:49 AM
USMCvet0311
Aug 1, 2015 07:45 AM
supersportsteve
Jul 4, 2015 12:02 PM
