Little hole in corners and taillights
Old Mar 1, 2005 | 03:48 PM
wes00silverado's Avatar
Default Little hole in corners and taillights
I noticed on my clear corners and on my tail lights that right around each bulb somewhere is a small hole that goes from the back into the housing. Are those to put in small LEDs or what?
Old Mar 1, 2005 | 04:25 PM
ITLstallion04's Avatar
No idea, ive noticed that too...
Also.. In your corners... does one of ur drl's go out more often than the other one? My driver's side has more mositure in it... i closed up those holes with some jb weld after drying out the corners and it still collected mositure... you having a problem like this?
Old Mar 1, 2005 | 09:38 PM
budhayes3's Avatar
PT's Slowest Truck
Could those holes possibly be vents?
Old Mar 1, 2005 | 10:40 PM
Mangled03gmc's Avatar
Baltimore Whore
they are vents so the light don't fog up
Old Mar 2, 2005 | 07:16 AM
I thought they might be vents but then they started fogging up some after I run the pressure washer over them so in my own mind I eliminated that one. Now I just try not to spray them. They my be vents and just not work right. Yeah my driver side fogs up more than my passenger too....
Old Mar 2, 2005 | 07:31 AM
I noticed those holes on my clear corners when I instaled then last week. They were on the stockers, too. But on both sets they were covered up with round stickers...did GM forget to take them off the factory ones? Anyways, I took the sticker off one clear corner and left it on the other to see if it made a difference in fogging up. Didn't seem to make that much of a difference. Someone told me to put a little Vaseline around the rubber lamp gaskets to help seal out water...I'll have to try that when it warms up.
walledition
Feb 24, 2026 03:27 PM
SS94S10
Jan 3, 2019 01:57 PM
97_ek
Sep 23, 2015 09:16 PM
dirt track racer 81
Sep 21, 2015 06:44 PM
screaminian47
Sep 7, 2015 08:20 PM
