(led) window switch install
Old Jan 28, 2004 | 08:45 PM
02chevyracing's Avatar
14 Second Truck Club
Default (led) window switch install
i need to know how to install the led blubs in the window switches,and no i dont want to buy a kit. i already have everything done except the window switches can anyone give me detail directions PLEASE!!
Old Jan 29, 2004 | 04:39 PM
KeukaZ71's Avatar
find user "macadayear". he has done this before
Old Feb 8, 2004 | 01:42 PM
MacADaYear's Avatar
Figure it out?
Old Feb 8, 2004 | 01:51 PM
RChevy4.8's Avatar
Originally Posted by -= MacADaYear =-
Figure it out?
Damn!
Old Feb 8, 2004 | 03:37 PM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
What do you mean you have done everything but the window switches?
Pics please
Old Feb 11, 2004 | 11:23 AM
why dont you help me figure it out. havent you already done it. i dont know how to take the switch apart. come on be a pal
Old Feb 11, 2004 | 12:24 PM
Uh, ok, take it apart, there's like this plastic thing that acts like a fiber optic...pull that off. Unsolder the filament bulb, and solder an LED in there.
Make sure you solder a resistor on there of the correct ohms. You will need to use Ohm's law to figure out what resistor to use. It's been so long I forget what I used.
What do you mean you've done everything but the window switches? What all have you done?
Old Feb 11, 2004 | 01:27 PM
the cluster,air controls fog, headlight control, underdash, domelight,door panels,
how do you take the plastic peace. just pull on it and it comes right off? im afraid it is going to brake.
Old Feb 11, 2004 | 04:01 PM
KeukaZ71's Avatar
ya, just pull up on the plastic piece that contains the power window and lock switches. there are retaining clips that hold it in place just like your dash. it is not possible to break. unless you
Old Feb 12, 2004 | 12:31 PM
Just to be clear, I am talking about the transparent piece of plastic inside the controls after you take the outer pieces off.
It will come out. I thought I was going to break it too, but you just gotta wiggle it alot while you pull on it at the same time.
Just be patient.
Good luck
