(led) window switch install
14 Second Truck Club
i need to know how to install the led blubs in the window switches,and no i dont want to buy a kit. i already have everything done except the window switches can anyone give me detail directions PLEASE!!
find user "macadayear". he has done this before
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
Uh, ok, take it apart, there's like this plastic thing that acts like a fiber optic...pull that off. Unsolder the filament bulb, and solder an LED in there.
Make sure you solder a resistor on there of the correct ohms. You will need to use Ohm's law to figure out what resistor to use. It's been so long I forget what I used.
What do you mean you've done everything but the window switches? What all have you done?
Just to be clear, I am talking about the transparent piece of plastic inside the controls after you take the outer pieces off.
It will come out. I thought I was going to break it too, but you just gotta wiggle it alot while you pull on it at the same time.
Just be patient.
Good luck
Just be patient.
Good luck
