LED dash swap install instructions: 03-08 Classic Silverado
Old May 11, 2010 | 04:49 AM
  #61
Foxxer's Avatar
Really nice! any difficulties while installing?
Old May 11, 2010 | 06:43 AM
  #62
Tootall's Avatar
Originally Posted by juicestain
I have a 2000 silverado. I've done the LED swap to everything but the A/C control. Problem is I took out the old bulbs and was getting ready to put the LEDs in but none of the connections seem to power the leds anymore , I've switched them around and everything. Are these bulbs like christmas lights to were if one buld goes out they all do, if so is there an easy ay to tell positive and negative connections. If this isint the case what could be the probles? Thanks
the A/C controls on the 99-02s are in a series . . . so if one goes out, they all go out . . . I don't know if I have pics of a completed one that I've done. It's best to use a meter and mark all of the "+'s" before starting . . .
Originally Posted by Bumpers
I wish you were closer I would let you do all mine... Half my bulbs are out and it would be sweet to have white
Unless you use really bright (really annoying) white LEDs . . . it has a little green tint to it . . . more like babby yack green
takes about 6-8hrs for your first time . . . I messed up my a/c controls on my 02 once, and then yanked out 3 sliders on the 03 and up A/C controls . . . so yeah it was a learning experience. . . . and yes too much heat in one spot will kill a board in 3-4 seconds
I've kind of lost interest in doing these . . .
Old May 14, 2010 | 12:44 AM
  #63
Perezownzu's Avatar
you can loose interest after you fix mine
Old May 14, 2010 | 08:24 AM
  #64
Tootall's Avatar
we'll get together !
Old May 15, 2010 | 08:24 AM
  #65
gs7793's Avatar
i need to redo mine so bad they're all starting to go out haha
Old Jun 9, 2010 | 10:22 PM
  #66
truckmann's Avatar
The lights in my stupid steering wheel buttons are going out already after replacing the switches not more than 2 years ago...
Old Jun 10, 2010 | 06:10 AM
  #67
Tootall's Avatar
cheap resistors or too much heat when soldering will do that . . .
Old Jun 10, 2010 | 10:53 PM
  #68
truckmann's Avatar
I haven't done LED's in mine. They were just replacement switches from GMPD. Not sure what I'm going to do about fixing them. I may just get some bulbs from radio shack to solder in. Not real happy that it burned out in less than 2 years though.
Old Sep 30, 2010 | 08:48 PM
  #69
Quazi81's Avatar
Registered User
Default Radio leds
I was wandering if anyone has or knows where i can find details on changing the lights to leds in the stock 2004 sierra crew cab radio? I have found the change over for the cluster and everything else but the radio.
Thank you any help is appreciated
Old Sep 30, 2010 | 09:02 PM
  #70
Perezownzu's Avatar
rofl gl finding someone to fix them for you... mine are going out and i havent been able to find anyone to fix them for ever...im looking in to just buying all new switches... tired of looking at a rave show all the time with them flashing..
