LED dash swap install instructions: 03-08 Classic Silverado
#62
I have a 2000 silverado. I've done the LED swap to everything but the A/C control. Problem is I took out the old bulbs and was getting ready to put the LEDs in but none of the connections seem to power the leds anymore
, I've switched them around and everything. Are these bulbs like christmas lights to were if one buld goes out they all do, if so is there an easy ay to tell positive and negative connections. If this isint the case what could be the probles? Thanks
, I've switched them around and everything. Are these bulbs like christmas lights to were if one buld goes out they all do, if so is there an easy ay to tell positive and negative connections. If this isint the case what could be the probles? Thanks takes about 6-8hrs for your first time . . . I messed up my a/c controls on my 02 once, and then yanked out 3 sliders on the 03 and up A/C controls . . . so yeah it was a learning experience. . . . and yes too much heat in one spot will kill a board in 3-4 seconds
I've kind of lost interest in doing these . . .
#68
I haven't done LED's in mine. They were just replacement switches from GMPD. Not sure what I'm going to do about fixing them. I may just get some bulbs from radio shack to solder in. Not real happy that it burned out in less than 2 years though.
#69
I was wandering if anyone has or knows where i can find details on changing the lights to leds in the stock 2004 sierra crew cab radio? I have found the change over for the cluster and everything else but the radio.
Thank you any help is appreciated
#70
rofl gl finding someone to fix them for you... mine are going out and i havent been able to find anyone to fix them for ever...im looking in to just buying all new switches... tired of looking at a rave show all the time with them flashing..
