Leaks in my truck
Old Feb 11, 2004 | 08:23 PM
SuthernFlames316's Avatar
Default Leaks in my truck
whenever it rains, my carpet right near the door sills is wet..i have not clue where it is leaking from. Anyone know where the hell it is leaking??
Old Feb 11, 2004 | 08:37 PM
v8
17,16,15,14,13,12,11 Drvr
check the third brake light for any cracks thats where mine was leaking from due to factory over tighting screws later, kevin
Old Feb 12, 2004 | 02:55 PM
O3GMC's Avatar
12 Second Club
make sure the grommet in the door jam that the speaker wires etc run through is 'clicked' in all the way. This is the large rubber grommet with the white platic clip inside......after I installed my stereo it wasn't pushed in all the way and there was a slight crack in the top and it didn't seal.....when it rained, all the water from the weather stripping directed the water flow right into that SOB and I literally had puddles under my carpet.........it took tons of rags and towels to dry it out.
Old Feb 12, 2004 | 05:33 PM
BigKID's Avatar
I need to check that on mine since I noticed some water dropletts on the inside of my back window yesterday.
Old Feb 13, 2004 | 09:37 AM
12sec.5.3's Avatar
I had a sliding glass and had to get rid of it because the outer casing cracked in 2 places and leaked all over the place.
Old Feb 14, 2004 | 11:30 AM
this has happened to me three times, ive taken it back to the dealer twice and they have fixed it but each time about 4-5 months later it starts doing the same thing again. its not a big deal but it is just a hassle, i remember they said somthing about a grommet or somthing being the problem but i dont remember the specifics
Old Feb 14, 2004 | 12:02 PM
4x4sierra's Avatar
It might be coming around the door jam. There is a plastic deflector made by GM that goes in on the bottom of the door and behind the door panel. Check with GM on service bulletins related to your problem. Mine was doing the same thing, installed the plastic piece and no problems any longer.
Old Feb 15, 2004 | 09:17 PM
Phatchevy's Avatar
mine is wet on the driver's side floor board. it's like the whole thing gets damp. i took mine to a dealer and they thought it was a plastic panel that i was missing that was allowing water to come in. then it started to get wet again and i took it back and they said that there was a hole in the firewall where the steering shaft goes into the engine bay. they resealed it for me but i don't know if it helped out or not. my carpet is still damp but not all that bad. does anyone have any problems/remedies like this?
wrb002
Aug 31, 2015 12:00 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
black6spdz
Jul 16, 2015 01:32 AM
1320Chicken
Jul 14, 2015 10:58 PM
Mzay
Jul 6, 2015 11:03 PM
