how to remove pin stripe??
Old Feb 16, 2008 | 08:34 PM
dimedsbc's Avatar
Default how to remove pin stripe??
what is the best way to get off the glue or whatever is on the back side of pin stripes... i tried using goo gone but that stuff is a b&$CH... would love for any help bc it looks like i *** since i pulled them off and still have the gluey stuff on it....
Old Feb 16, 2008 | 09:05 PM
beastmode's Avatar
Import Moderator
ive always just used wax and a rag instead of one of those applicator pads, takes a little work
Old Feb 17, 2008 | 08:55 AM
TG02Z71's Avatar
If it's the sticker kind use a heat gun or hair dryer to make it elastic, larger sections will pull of a lot easier. Then wipe with WD40, wash and wax, done.
Old Feb 17, 2008 | 10:00 AM
dimedsbc's Avatar
is WD40 clear coat safe??
Old Feb 17, 2008 | 10:11 AM
dirt track racer 81's Avatar
ive still gotten some of that stuff on my truck and ive tried everything and it still wont come off
Old Feb 17, 2008 | 10:12 AM
UBLUZIN03's Avatar
Yep thats what i used. Just make sure you give it a good wash to get all the WD off..
Old Feb 17, 2008 | 02:24 PM
dimedsbc's Avatar
used the wd40 then a wash fallowed by a clay bar and wax to the whole truck worked but was still a b!t(H.... thanks for the tip
Old Feb 21, 2008 | 06:15 AM
11 Second Club
go to a body shop and pick up a decal remover.. they are usually under 20 dollars.. it looks like a giant eraser.. you mount it on a die frinder or drill and it won't harm the paint.. my body guy pulled mine off with one in about ehh. 15 mins..
Mike
Old Feb 21, 2008 | 07:28 AM
Red03SilSS's Avatar
Just go to CarQuest or Tasco and get 3M Adhesive Remover. Its in a Red & White tin can. I would know this bc I own a body shop. The chemical is clear coat friendly also!
Old Feb 21, 2008 | 08:38 AM
SILVERBIRCH's Avatar
I heard nail polish remover works.
