Help with rim size/ rubbing issues.
Old Jun 16, 2005 | 06:57 AM
BLACKHD01's Avatar
Default Help with rim size/ rubbing issues.
I have a 01 2500HD with the torsion bars turned up to level it out in the front, I am running Nitto 285/75/16's on the stock rims, I was wondering if I could run 17x8 rim with maybe some 285/70/17 and not have any rubbing issues?
Old Jun 16, 2005 | 08:51 AM
BLACKHD01's Avatar
ttt...
Old Jun 16, 2005 | 02:49 PM
wes00silverado's Avatar
I'm runnin 275/60/17s and they aren't even close. So you could probly cram em in there. Hopefully before long i'll be runnin 260/45/20s or something like that.
Old Jun 16, 2005 | 03:14 PM
BLACKHD01's Avatar
Thanks for the info, I thought that they would but didn't know.
Old Jun 20, 2005 | 08:27 PM
Default tire and wheel size
i have a set of 305/75 16 on stock rims on my 02 2500hd, torsion bars turned all the way up with 1 1/2 blocks in the rear. they do not rub, but i had to crank up the torsion bars all the way, and the blocks in the back to level it.
Old Jun 20, 2005 | 08:43 PM
turbo595's Avatar
It depends on the offset of the new 8" wide wheel. The wheel will make the tire have a wider footprint and depending on the backspace, rub the valance and the rear part of the wheel opening. The factory wheel has roughly 4 3/4" - 5" backspace. Going wider, you should atleast have that....up to about 6". H2 wheels are 8.5" wide and have a 5 1/2" backspace and are a very affordable upgrade. You would be fine with those tires on the H2 wheels and not have to adjust the bars anymore than you already have. Hope this helps.
Old Jun 21, 2005 | 07:24 AM
BLACKHD01's Avatar
Thanks for the info turbo595, I have looked at the H2 wheels they look pretty sweet on the HD's, what center cap do they use in place of the H2 cap? I couldn't tell which one it is or if you just use the one off of the oem HD wheel.
Old Jun 22, 2005 | 08:00 AM
turbo595's Avatar
Yes, the one off the HD wheels. Some have had to cut the nubs off the back of the center cap to get more threads to hold them on.
Old Jun 22, 2005 | 08:49 AM
BLACKHD01's Avatar
Thanks, that is what I thought.
Old Jun 27, 2005 | 08:31 AM
4SHONGO's Avatar
Go to rimstop.com and use there tire size calculator.
Idryfly5
Sep 2, 2022 08:55 PM
wretched73
Oct 28, 2015 09:21 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
kmcn47
Sep 17, 2015 01:12 AM
