Headliner
Old Mar 23, 2006 | 09:16 PM
03lowriderss's Avatar
Default Headliner
can any one show me(pics) of how to remove my headliner, as far as where the clips are and how to pull them?
Old Mar 24, 2006 | 05:53 PM
TTT... the message that you have entered is to short it must be at least five characters
Old Mar 25, 2006 | 06:26 PM
Someone has had to have taken out there headliner right?
Old Mar 25, 2006 | 08:57 PM
jm's customs's Avatar
i have but have no pics its ever thing on your headliner that holds it up the lil hanger clips were a pita too me ill see if i can get up some pics
Old Mar 27, 2006 | 10:24 AM
sorry it took me so long but here it goes
this is how the handles look
there are two plug thingys, get a knife and pry they out a lil and pull out with hand these do not come all the way out. pull on handle afterwards to pull out of holes, the handle will still be attached to headline but not to roof
this is how the hookes look
just grab sides of hook with hand and pull down it should be fairly easy. then pull out of holes, this will also still be attached to headliner but not roof
this is the clips for the vizors, i think thay are a torks (star) just un screw, same for the other part of the visor
so when you get done the headliner will still have the hookes and handles attached to it but you will be able to take out of truck and if you have a extended cab there is a thing between the 1-2 door and the 3-4 door just pull it will pop all the way off
hope this helps good luck
Old Mar 27, 2006 | 11:36 AM
jm's what about the overhead pocket thiny is there any trick to removing that
Old Mar 27, 2006 | 11:48 AM
the roof console thingy, there is a screw up by the windshield take it out the frount should fall down a lil then slide the whole thing foward and it should come right out
Old Mar 27, 2006 | 11:58 AM
i have a full console thing, it goes from the windshield to almost the light. see the hole in the roof through the back hole in the headliner, that is where the back part of the console goes, there are two lil slider thingys on the console that go in the back holes, and the one screw up front that is all that holds it on
Old Mar 27, 2006 | 04:51 PM
thank you
MarineBlue03GMC
Aug 31, 2006 03:09 PM
4.8redchev
Mar 11, 2006 04:38 PM
hirdlej
Mar 20, 2005 07:02 PM
