Headlight Mod for $1
#31
thanks for the great article
on mine, i cut the yellow wire and grounded it to the body. you can see the passenger side with no mod, and driver's side with mod.
i have my fogs rigged to my stereo. if stereo is on, so are the fogs. wire taps are great
#33
Originally Posted by ohohsilverado
can i run my drls at night, i wanted to run them with the turn signal lights. sorry for the hijack
if you have a 03 and up, I know you can just splice them into the turn signal wires, and replace the DTRL bulb with a orange one, so the whole bottom light is one big light, like the 88-98 trucks. But no more DTRL's
#37
[QUOTE=KeukaZ71]thanks for the great article
so all you do is cut the yellow wire (that is behind the headlight) and ground it... right???
#38
For the whole bottom light to be yellow try these two
https://ls1tech.com/forums/showthread.php?t=240382 PART 1
https://ls1tech.com/forums/showthread.php?t=233510 PART 2
Right, I think for the 02 and under like to 99, you cut the yellow wire at the lowbeam light and ground it to get the four high.
If I could get my hands on a 99-02 truck around here I could figure out anything that you need for electrical stuff.
#39
[QUOTE=*WILDSTYLE 5.3*]
yup, that is exactly what you do.
snip that yellow wires that comes right out of the low beam bulb, leave enough room to crimp a butt connector. then i ran new wire to any available nearby bolt, sanded the paint, and grounded the wire. it was super easy. i could take pics of the wiring in the engine bay if you would like
#40
cool im going to do this right now right now not later later!!!1
pics would be great !!!!
