Guy's with 2/4 drop look here.....
Old Feb 19, 2004 | 10:10 PM
dust6928's Avatar
Default Guy's with 2/4 drop look here.....
did you have to buy the carrier bearing kit when you dropped your truck? i know i might have to buy some pinion shims but i have heard yes and no on the kit or do you just have to do it and see what happens????
Old Feb 20, 2004 | 11:06 AM
depends on your truck
I have some trucks that did not need it
Mine needed it with 2" shackles
It depends on the frame
Frames are built inconsistent
really depends on your frame
I had a vib at 12 mph when I put shackles on !!
Old Feb 20, 2004 | 12:19 PM
RCSB you will not need one.
ECSB you will need one.
Old Feb 20, 2004 | 04:59 PM
dust6928's Avatar
i really didnt want to hear that!!!! thanks guys, dust.......
Old Feb 20, 2004 | 05:06 PM
onyx's Avatar
14 Second Truck Club
huh?... pinion shims?... whats up with this?... i have an EC... and have a 2/4 hotchkis waiting to go in.
Old Feb 20, 2004 | 05:21 PM
dust6928's Avatar
shims go in your leaf springs to help correct the driveshaft angle after you lower a truck. when you lower it drive it and if you feel a little shimmy in the drivetrain when you accelerate you will need them. i talked to truckperformance and they said that on just a 2/4 you shouldnt need the carrier bearing kit but like you guys said, every vehicle is different.
Old Feb 20, 2004 | 06:00 PM
I have ECSB and installed 3 inch shackle drop and have no vibrations. But I would agree that every truck is different,
Old Feb 20, 2004 | 07:16 PM
Silverdoman's Avatar
I had a viberation in mine before lowering it. Dealer told me some 99 they could not get all viberation out. When I lowered mine the viberation was bad and installed center bearing and no viberation on normal driving. I get it some time under hard starts but not often. It could use some more adjusting but I don't feel like doing it.
Old Feb 21, 2004 | 07:05 AM
onyx's Avatar
damn... more money to spend... hopefully i wont need it... but if i do, where can i pick it up?
Old Feb 21, 2004 | 07:17 AM
IF you got the Hotchkis kit, they are already mounted onto the leaf springs, and if you have an extended cab, there is also a shim for the transmission mount.
Don't know about others.
