Guage Replacement Cover!!!
Old Feb 26, 2004 | 09:45 AM
2001si3rr@'s Avatar
Originally Posted by 01silverado
i have power locks and they don't lock automatically, was this for 99-00 only?
If you look in your owners manual you should find the programing instructions to program your door locks. If not you could go by the dealership and ask them. It was something like: Turn key to on position (not starting the truck) push lock and unlock in whatever sequence the manual says and it will set the locks to do what you want. Hope this helps.
Old Feb 26, 2004 | 05:25 PM
atomoverride's Avatar
Originally Posted by Fast4.8
The reason to warm the truck up is mainly for the tranny and temp gauge.
Use a golf divot repair tool to get the needles off.
Well the best way that I heard of doing it, turn the truck on, but do not start it. Write down what needle is at where.
Remove cluster, Remove clear plastic part, Remove needles, replace face, put back in half way leave it exposed and not screwed in.
Turn truck on, but do not start it, put your needles back on per your writtendown specs. Then put plastic piece back on, screw in, and put it all the way back together. That should be it. No warming up needed, make this easy as pie.
wrb002
Aug 25, 2015 03:56 PM
lycominghunter
Aug 15, 2015 12:26 PM
Denali08
Aug 9, 2015 04:34 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
