Guage install help
Old Jun 7, 2005 | 03:51 PM
foxracingfreak's Avatar
Default Guage install help
I jsut got my autometer tranny temp gauge today. and i was wondering where is a good place to install the sending unit. it is an electric one. the direction say to drill a hole in the tranny cover. but i thought maybe someone would know where there is already and existing hole. let me know thanks.
Old Jun 7, 2005 | 06:34 PM
ThunderZ28's Avatar
12 Second Club
NONONONo, dont drill a hole
Phew!!!!! glad we caught you before you did that..
there is a plug right above the shift linkage on the drivers side of the trans..
unscrew it from them trans and screw you new unit in where it was..
it's a perfect fit..
make sure to use some teflon on the threads, just incase it may leak.
hope this helps.
Daniel
Old Jun 7, 2005 | 10:40 PM
thanks.... i wanst planning to drill into the side i knew there had to be a spot for one. thanks.
Old Jun 8, 2005 | 12:33 AM
thunder550's Avatar
High on diesel fumes
Yep that's where I did mine works perfect.
Old Feb 18, 2006 | 12:04 AM
METALMULISHA777's Avatar
i drilled mine into the pan whe i was doing my shift kit.... theres a pic of it on my cardomain page... doesnt leak , no problems.. works fine... def use teflon either way
Old Feb 18, 2006 | 11:49 AM
BlackLM7's Avatar
hope this helps.
Daniel
I also used this plug. Clean installation and it works great.
Old Feb 18, 2006 | 12:48 PM
nightmarechevy's Avatar
I used the plug too. Great fit and no leaks!
LCHEE
Oct 24, 2020 04:10 PM
wrb002
Aug 25, 2015 03:56 PM
tgui
Aug 22, 2015 12:08 PM
zblee
Aug 3, 2015 03:45 AM
Offroadunleashed
Jul 20, 2015 02:25 PM
