Getting closer to painting the hood
Old Jul 9, 2008 | 03:15 PM
  #141
KySilverado's Avatar
Originally Posted by coldkillinTA
Youre gonna want to do an orange pad (heaviest cut) with your strongest polish. if youre patient enough to order another product, Id highly recommend Menzerna Super Intensive Polish (SIP) with an orange pad. With the PC on setting 1 or 2, spread the polish evenly, then immediately turn it up to 5.5 or 6 and work the polish in going very slow and only using probably 5lbs of pressure on the machine. Youll probably make 3-4 passes (putting more polish on the pad in between). Do this until you cant see anymore sanding marks, then go to a light cut/final polish on the white pad to get rid of any haziness left behind by the SIP. then go strait to you Last Step Process(LSP) sealant, wax, machine glaze, etc. Good luck!
Thanks for the comments and suggestions. I agree. I don't know if I have the ummm horsepower I need for the first cut. I'm going to try what I have already first. 1> Because I'm a bit impatient at this point and 2> I've already spent money on it. If it doesn't go well I'll stop and possibly order up some more stuff.
Old Jul 9, 2008 | 04:27 PM
  #142
95 bright teal's Avatar
Yeah take your time with the buffing, i wetsanded my hood and about 15 touchups on my truck then went back and buffed it out.
first time around, i didnt put enough weight on the buffer( i was scared) and then i used a glaze instead of a polish then waxed it, it took about a day looked alright but sanding marks were still there
second time a week later went back with heavier pad worked the sanded areas real good got some meguires polish spent along time making sure to realy compound it in then waxed again came out alot better, it was a much longer day! and now 3 months later its still looking good!
take your time and of course have fun!!!!!
Old Jul 9, 2008 | 05:23 PM
  #143
So far this combo is working pretty good. Went and found the 3m compund... says good for taking out 1200 to 2000 sanding. Couple passes with it and the pad in front of it. Switch over to the Meguiars and pad in front of it for a couple passes. It's really easy so far.
Old Jul 9, 2008 | 05:26 PM
  #144
Yeah the buffing is scary. Thats why I have the orbital... damn near impossible to screw it up. I'm glad I have a little bit of experience with this part of it. Enough that at least I have a little more confidence with it. The spot lights I have really help look at it before putting up the buffer. I don't want to do it again
Yes I am enjoying this part so far.
Old Jul 9, 2008 | 05:30 PM
  #145
BlackGMC's Avatar
Resident Retard
looking GREAT, remember last stage is glaze, and no wax for 45 days...
  #146
coldkillinTA's Avatar
Man! lookin good so far! can't wait to see it on the truck!
Old Jul 9, 2008 | 05:55 PM
  #147
BlownChevy's Avatar
blownerator
25 Year Member
ehhh, high speed buffing is easy!
Great work, I will ship you my truck to do next!
Old Jul 9, 2008 | 06:24 PM
  #148
TouchOfEvil04's Avatar
Yep, i think i need to ship ya both of my trucks as well haha.
Looking very good.
Old Jul 9, 2008 | 06:25 PM
  #149
trever1t's Avatar
2nd fastest 5.3 ECSB
^^ forget him ^^ Bring that PC with you next time your in the hood!
Old Jul 9, 2008 | 06:54 PM
  #150
Thanks for all the tips dude. You've been a life saver!
Can't wait myself. At the rate I'm going I should finish it up by the weekend.
I agree. The buffing is the easiest part so far. Uh your sig says "no truck"
Looking very good.
That would be an expensive buffing job
Hahaha have PC will travel
It's by no means perfect guys. Some of the little dusties you can see directly in the light. Look like the little nail heads you see in drywall or something. I started to work on them but couldn't find them when I'd go to touch them, so I said the heck with it.
I wish I could get a good picture in the right light to show the depth.... the color and metal flake are gorgeous.
