Getting closer to painting the hood
#132
lookin great man, make sure you wash it before buffing.... Also make sure you wash it inbetween the different compounds and switch out your buffing bonnets... Is the buffer you using a high speed buffer?
#133
Porter Cable Orbital... has numerous speed settings. All the way to 10... Is that high speed?
#134
#135
so have you worn off all the skin on your fingers? That was the worst feeling... I remember sanding for days at the shop I used to work for and all my fingers had like zero skin on them and they were really sensitive, on the other hand the girl I was dating at the time, liked my hands smooth rather than all rough...
#136
#137
A PC buffer is not high speed. its a DA(dual action) buffer which is very safe to use and will NOT burn through paint. its impossible. it may or may not get ALL of the sanding marks out but it will AT LEAST get 90% if not all. what pads did you get? what exact polishes/compounds did you get?
#138
Here is a picture to one bottle of product line I got for the buffing. 1-4 cut polish. I did read on the bottle last night that the 1 is not for a DA only its for a HS. I've got foam pads, white, blue, orange and black maybe... then shaggy cover of some sort. Don't think its wool.
#139
#140
Exactly why I got a PC. I know it will take more work than a high speed but I'm a novice so.
