Few Nitrous install pics, I'm getting started :)
Old May 15, 2008 | 07:07 PM
  #21
Phantom's Avatar
11 Second Club
just fyi...don't drill through your gas tank when making the hole for the blowdown tube
Old May 15, 2008 | 08:54 PM
  #22
chevytruckguy's Avatar
Everything looks good. I was able to run my blowdown tube through the cab vent in the back wall of the cab. Also, I mangled my original tube, so I found some 1/2" aluminum fuel line and bent it to fit. Most race shops carry it, I found it at a circle track race shop. Also, you can use the AN-8 flare nut and fitting to make your own blow down tube with that 1/2" aluminum line. All you'll need is a single flare tool. I was able to hide all of the solenoids under the engine cover, and hide the braided lines with that black wire loom.
Old May 15, 2008 | 09:29 PM
  #23
Mangled03gmc's Avatar
Baltimore Whore
Yah I made sure not to let the whole bit go threw the floor, when mounting the tank. I fig there could be something under there that could ruin my day..
I am going to make my blow down tube from a stainless pipe, polish it up. Also I am using all stainless hardware. I want to take the dome light over ride button and use that for my actual nitrous button, instead of the wide open switch, but thats down the road a lil. I am going to try and hide the sols, mask the lines, buy tring to run them in other wires looms, might even get the bottle painted like a fire ext Thanks for all the comments an info guys.
John
Old May 15, 2008 | 09:50 PM
  #24
LMSeven's Avatar
Looks good John. I still haven't installed my blow down tube yet. I think the burst disk is rated for 1200 psi. I still need to get a pipe bender and route it out of the cab vent. I was thinking about buying the appropriate sized braided n20 line and hooking one up to the blow down tube fitting and using that to route it out instead of dicking with a pipe bender for hours. Never really looked into it since my track's tech is signing a paper and shoe polish on the windows
Old May 15, 2008 | 10:03 PM
  #25
Baltimore Whore
Hmm could you get away with running Ssteel braided line for a blow down tube? Anybody.. If ya can then I might do that. I personally think that tube looks like ****, might only run it at the track, but who knows....
John
Old May 16, 2008 | 10:01 AM
  #26
JeffT's Avatar
John
Yes, you can run SS braided hose for your blow down and be track legal. You'll need a fitting to attach to the bottle, a length of SS hose, a fitting for the other end of the hose and a bulkhead fitting. Any of the nitrous sponsors should be able to hook you up.
Old May 16, 2008 | 03:10 PM
  #27
Baltimore Whore
Awsome, luckly I work for a hydraulic shop and SShose and fittings are at my finger tips...
John
Old May 19, 2008 | 04:09 PM
  #28
LMSeven's Avatar
Well thats the first good idea I've had in a while
When I was looking into it, the blow down fitting size on the bottle was 8AN, I could be wrong.
ARC
57
Feb 21, 2022 10:54 AM
Greatdivider
Sep 9, 2015 09:52 AM
chacho44
Aug 17, 2015 03:36 AM
Slammed96
Jul 27, 2015 07:22 AM
therock
Jul 25, 2015 09:23 AM
