Drag wheels/tires - Let's see them!
Old Feb 26, 2013 | 11:24 PM
  #91
foose04's Avatar
Originally Posted by LOstrolencki
truck looks absolutly glorious man!
what brake set up are u running in the rear to get those 15" bogarts to fit? whats the backspace on the wheels? what gear ratio?
Thanks bud! Running the blazer calipers on the rear with a good bit of grinding and the back spacing is 7.5". running stock 3.73's.
Cut a best of 1.49, avg 1.51-1.53 60's.
Old Feb 27, 2013 | 10:32 AM
  #92
LOstrolencki's Avatar
thanks for the intel man, one more thing. the blazer calipers u are running on the rear, did the silerado rotors, brake lines, and bolts for the calipers work or was there any other custom fabrication besides grinidng? and on the front i noticed u still rocked a 15" wheel, did u have to swap the front calipers out too?
Old Feb 27, 2013 | 12:32 PM
  #93
03regcab sierra's Avatar
S10 blazer calipers are direct bolt on from stock just grind em till they clear the wheels. Front 15s work as long as u have 99-04 brakes. Bigger brakes that 05 up have will require grinding or wheel spacer
Old Feb 27, 2013 | 02:11 PM
  #94
DTHPROOF's Avatar
FWIW, I ground my stock rear calipers down to fit the 15" wheel my slicks are one. Worked great and hasn't presented a problem since I did it 6 months ago.
Old Feb 27, 2013 | 04:10 PM
  #95
Only issue is the banjo bolt won't clear for the deeper back spacing on stock calipers
Old Feb 27, 2013 | 04:58 PM
  #96
DTHPROOF's Avatar
Oh, I gotcha. Sorry for the de-rail.
Old Aug 14, 2013 | 08:33 PM
  #97
f body lover's Avatar
Guys I want to fit some black 16s on my 2000 Silverado to make it look like a Nascar its disk brake whats the maximum width and what backspace I can run? If 15s are possible how much grinding the calipers it would need? Too much till the caliper is weak or just little? I tried the search and I found this topic all trucks been posted are amazing
Old Aug 15, 2013 | 04:27 AM
  #98
HANS's Avatar
Originally Posted by skeet
definitely need better pics
i just humped my computer screen. looks damn good
Old Aug 15, 2013 | 08:09 AM
  #99
dirt track racer 81's Avatar
5 lug summit warriors up from and 5 lug summit stars on the back
Old Aug 15, 2013 | 11:20 AM
  #100
How did you convert from 6 lugs to 5? Wheel specs please and backspace
