drag radial size????
Old Oct 9, 2011 | 04:02 PM
ltr450ryder's Avatar
Default drag radial size????
hey i was looking at buying drag radials for my truck but idk what to go with 28 29 or 30 the truck has 4.10 and i prolly will use them on the street sometimes to what do u guys think
thanks
Old Oct 9, 2011 | 06:21 PM
custm2500's Avatar
Ph.D. in HUBRIS
I would reccomend a bias over a radial. At your current power lever a DR will probably work well since you aren't going to be pushing it very hard. But if you plan to go much faster a radial will be dificult to make work especialy on a truck.
The 28 should be great. That is what I have on my truck and expect it to easily take me into the 11s next year. The shorter the better in most cases but with you haveing a 4.10, smaller will quickly cause you issues on the big end. A 28 mwill look good on the truck and should offer you a great final drive ratio.
Old Oct 9, 2011 | 07:00 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
What size wheels are you going to use?
Old Oct 9, 2011 | 07:57 PM
I have 16x8 and a set 17x8s whatever I could find that would work better with my truck and I figured radials for the whole driving on the street sometimes
Old Oct 9, 2011 | 08:00 PM
and i will putting a 383 in it sometime in spring next yr so will hopefully have close to 500 or so at at the wheels
GMCtrk
Oct 5, 2015 11:18 AM
old motorhead
Sep 29, 2015 08:22 PM
Slammed silverado
Sep 28, 2015 06:14 PM
twake_410
Sep 25, 2015 10:09 PM
Closer_2001
Sep 24, 2015 09:15 PM
