cast aluminum detail question
Old Feb 19, 2019 | 11:35 PM
  #31
_zebra's Avatar
makes children cry
taking that last point a step further... without changing anything else on your setup, you won't see any additional boost gain by going bigger on the inlet side than the blower can consume. so let's say you metered your blower inlet behind the TB at WOT, max RPM, and were at 1bar (no vacuum) using the 102... then, from the way i understand, porting further to slap on a 108mm TB wouldn't benefit you any more because the blower's already pulling all the air it's capable of.
make sense? so reducing inlet and outlet restriction are both beneficial & both increase efficiency: inlet feeds it what it needs; outlet lets it move through with less effort or heat build-up.
Old Feb 20, 2019 | 12:04 AM
  #32
_zebra's Avatar
makes children cry
holy cow!! the pics didn't load the first time, so i thought you were talking about porting the lower manifold to the heads.
yeah, i doubt opening the discharge port would do anything good for you.
Old Feb 20, 2019 | 09:57 AM
  #33
1redta's Avatar
look at vapor honing availability in your area
Old Feb 20, 2019 | 01:00 PM
  #34
TXsilverado's Avatar
I put in an order with superchargersonline. After having the injectors cleaned/flowed I should have roughly 1,800 into the entire kit (using a spare pump and exchanger already on hand)
on the way:
HD tensioner
tensioner bracket w/ pullies
intercooler pump harness
intercooler reservoir
5/16 & 3/8 fuel pipes with new o-rings
magnuson steam cross over tubes
supercharger oil
anaerobic rtv
flange bolts
throttle bracket
intake manifold gaskets
J tube O-ring
lid to tub seal
I'm sure I could have saved a ton of money by piecing it all together from several venders, but the convenience of the 1 stop shop was worth it.
Old Feb 20, 2019 | 01:14 PM
  #35
1FastBrick's Avatar
Custm2500's Rude Friend
Hmmm... sounds like something I said to do 5 days ago...
Did you ask if he had any extra cases?
Old Feb 20, 2019 | 02:47 PM
  #36
nah, the case is fine. there are no high spots and I countersunk th holes to prevent any potential sharp edges. I didn't want to call SCOL and waste their time before I was ready to pull the trigger and spend money.
Old Mar 20, 2019 | 04:19 PM
  #37
All of the parts arrived, and now i'm having 2nd thoughts. Am I retarded for supercharging a perfectly reliable 17 year old 240,000 mile old LQ4?
Old Mar 20, 2019 | 09:18 PM
  #38
1FastBrick's Avatar
She is just Broke in. Let her rip!!!!
Old Mar 21, 2019 | 10:25 AM
  #39
is there a point where i should consider replaceing OEM springs? I dont plan on adding a cam, and dont plan to spin it over 6k. this is the first motor LS engine i've left alone for more than 10k miles LOL.
Old Mar 21, 2019 | 11:33 AM
  #40
1FastBrick's Avatar
My neighbor broke a spring on a stock 200K mile engine. A fluke I guess. I dug one out of a pile and replaced it. Still going strong.
If your concerned, either get some BTR LS6 replacements for $69.99 or the GM LS6 Blue springs for $74.99
