Air horn finally installed
Old Jun 21, 2006 | 06:34 PM
MikeN's Avatar
Default Air horn finally installed
Welp, finally got around to finishing up my air horn install. Was trying to find stealth places to do the horn, and get a small tank I could hide as well.
Here is a quick video (Give it some time to load)
Old Jun 21, 2006 | 06:52 PM
Tan327's Avatar
Clean job, sounds great too. I might have to try this, it beats going out and buying the can air horns everytime..
Old Jun 21, 2006 | 07:14 PM
MikeN's Avatar
Yup... did it semi-cheap too. I just did a shrader valve on the tank, so I can just use a regular air chuck to fill the tank when I need to. You can do alot of blasts with 3-5gal of air I can always add a compressor later easy enough as well.
Old Jun 21, 2006 | 10:14 PM
budhayes3's Avatar
PT's Slowest Truck
Sweet set-up, sounds good. You could always get your own compressor that plugs into the cig lighter/aux input to fill the tank when it runs out also...get a compact one that'll fit with your roadside emergency kit if you have one. (Truck Air seems to be a decent one from what I've heard) There's also rechargeable compressors, and jump starters that have compressors in them also...alot of these items can be picked up right at WalMart, K-Mart, Home Depot, parts stores, etc.
Corvette454l88
Sep 1, 2016 01:24 AM
thunder550
Oct 8, 2015 04:53 PM
mrhino
Aug 7, 2015 10:01 AM
alex226
Jul 27, 2015 07:12 AM
Suburban2500
Jul 14, 2015 02:10 AM
