Aftermarket brakes????
Old Jul 14, 2006 | 10:49 AM
  #21
SAMOANBUILTGMC's Avatar
There is no performance difference in a drilled and slotted rotor or a plain faced rotor. Drilled and slotted rotors really doesn't dissipate heat any faster either. I work for Wilwood Engineering and the owner here was real hesitant on doing the drilled and slotted rotor because of it. We had to come out with it because of the demand.
Unreedemed said it, most of the braking is done with tires. The other is rotational mass. By drilling and slotting the rotors, you are just taking mass away from the rotor which can cause cracking or warpage.
Old Jul 14, 2006 | 11:01 AM
  #22
Originally Posted by SBTork
The look is an added bonus when it comes to big drilled and slotted rotors, first and foremost they always perform better. Just test out a set for yourself and take your instructor along with you for the before and after....it might just surprise him.
Are you testing the stock braking system versus a BBK? Of course you're going to brake better if you upsize in rotor and swept piston area.
Old Jul 14, 2006 | 11:12 PM
  #23
SBTork's Avatar
RustyD
May 23, 2016 07:04 PM
turbo6c3
Oct 5, 2015 06:11 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
murderedSS
Sep 27, 2015 10:16 PM
