4/6 or 5/7 drop on 22
Old Jun 24, 2006 | 11:35 AM
jus1975's Avatar
Default 4/6 or 5/7 drop on 22
What backspacing and tire size would work with a 4/6 or 5/7 drop. I want as wide a wheel as possible.
I noticed somewhere, someone narrowed there rearend. but I cant remember how much. I would like to do the same and possibly run 22x12 rears or wider or 22x10 with a hell of a lip. What do you guys think?
Old Jun 24, 2006 | 09:40 PM
Gran Patron's Avatar
The lowest you can go with a 4/6 will be with 22's! I would with a 22x10 at the rear with 285/35/22 tire's and with a 265/35/22 up front. With the 5/7 drop no bigger than 20's. A guy I know has a 5/7 on his 99 RC with 20x10's with 295/40's and 20x8's wrapped on 245/35's. Said it rode just like stock and was more than happy with it.
Old Jun 25, 2006 | 10:12 PM
ChevyTrukRacer99's Avatar
I saw the truck with the narrowed rear end, it was on the cover of truckin a while back, it was pretty sick lookin cause the lip on the rear wheels was like 6"! It's gonna be hard to get a 10" wide wheel up front if u want a lip on it and be able to go that low...the fronts can be tricky cause there are so many variables with the steering and such.
Old Jun 26, 2006 | 03:01 PM
02BlueStepside's Avatar
A 4/6 with 22s is enough work, 5/7 wouldn't be an option unless you really want to cut your truck up.
Old Jun 26, 2006 | 06:21 PM
jus1975's Avatar
what kind of cutting are we talking about. I was wanting to tub and cut the inner fenderwells but I dont know where to cut.
Old Jun 26, 2006 | 06:37 PM
TWANKYDEUCE's Avatar
5/7 and 22s wont work very well. only unless you are willing to really **** up you front fenders. the tires will hit when you turn all the time. When I had a 4/6 i had a little trouble turning and hitting.
Old Jun 26, 2006 | 06:39 PM
jus1975's Avatar
Where will the tires hit? And what will you have to cut?
Old Jun 26, 2006 | 08:35 PM
Tires will hit the fender, not the inner fender that you could tub, but the outside of the fender.
Old Jun 27, 2006 | 03:05 PM
jus1975's Avatar
I would still like to tub the inner fenders. Where do I cut and where does the fusebox, master cylinder, and windshield washer fluid tank go. I can move the battery under the rear seat. I wanted to do this to avoid any future problems and if I decide to lay frame.
Old Jun 27, 2006 | 06:48 PM
twanky will be able to help you more than I since his is bagged and already tubbed for the 22s.
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
Chewy07
Nov 14, 2015 09:46 PM
Gadgetized
Oct 22, 2015 09:06 AM
smok'nZ
Oct 6, 2015 01:14 PM
twake_410
Sep 25, 2015 10:09 PM
