3/4 Drop too bouncy
Old Mar 17, 2003 | 02:58 PM
BigKID's Avatar
Default Re: 3/4 Drop too bouncy
What brand springs did you use for the front? You may have gotten a spring that is too soft.
Old Mar 23, 2003 | 11:33 PM
Texas Terminator's Avatar
11 Second Club
you need to change your shocks. shocks are designed to work in a specific "idle" area, and by lowering, it you have taken it out of that area. make sense? don't skimp on replacements or they will be worse than what you already have. use the edelbrocks if you can afford them. at least for the front.
Old Mar 24, 2003 | 07:08 AM
Domeskilla's Avatar
You lowered it the "cheap" way. For better ride and camber, you should have used spindles and 1" coil and shakles/hangers or a different leaf pack. If new shocks dont fix anything, looking into the brand of equipment used and the method. There is a reason ppl use spindles. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Mar 24, 2003 | 03:45 PM
Domeskilla's Avatar
Never had a problem here. What DOES come in affect is if you rub and are forced to turn wider.
btw, setup on my old truck was a 91 ext cab lowered 4/6 and no problems. Also had 18's.
Old Mar 25, 2003 | 12:33 AM
but don't spindles increase yur turning radius? i'd rather be "cheap" than have to make a turn a mile wide
walledition
Feb 24, 2026 03:27 PM
Velocity1
Oct 12, 2015 10:39 PM
Superman09
Sep 25, 2015 05:55 AM
fortune46x
Sep 16, 2015 08:18 AM
