2004 GMC 2500HD Front End?
Old Nov 16, 2003 | 06:24 PM
Mr Powell's Avatar
8 Second Club
Default 2004 GMC 2500HD Front End?
What are my options as far as grill's, Denali Headlights, HIDs, etc?? If I could put the denali grill in I would like to, but I dont know if I am able to. It would match the family's 04 Denali, which is the same color as the truck.
Thanks for the help.
Old Nov 16, 2003 | 06:57 PM
CHAGO's Avatar
not too sure about swapping to the Denali-style headlights/grille since its a HD.
I'm sure they make after market grille's for the HD, but not sure if they have a Denali type for a HD.
Old Nov 17, 2003 | 04:19 AM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
If the headlamps for your HD are the same as the regular Sierra (I think they are), then you can put the Denali projectors in there and get a nice HID kit to throw in there. Should look good and visibility will be better than stock.
Old Nov 17, 2003 | 06:50 AM
Scream's Avatar
MOOBIES Moderator
The Denali headlights will work, no problems.
The Denali grille/fascia will not. The 03+ Sierras have a different grille and bumper than the 02-down. While a swap isn't impossible, it's a lot harder on the 03+ trucks because the framehorns are different. And I beleive that the brackets for the HD are different than the 1/2 ton trucks.
Here's a parts list for the entire conversion:
99-02 Yukon/Sierra to Denali Front End Conversion
# 15046662 - Filler between grill and bumper - LH
# 15046666 - Filler between grill and bumper - RH
# 15150999 - Parking lamp - LH
# 15151000 - Parking lamp RH
# 15764319 - GMC Denali Grill
# 15166756 - Headlight - LH
# 15166757 - Headlight - RH
# 12479754 - Bumper cover
# 14093088 - Retainers (7 needed)
# 15149708 - Retainers (12 needed)
# 15153490 - Insert
# 15060470 - Impact bar
# 16516335 - Fog lamp Assembly - LH
# 16516336 - Fog lamp Assembly - RH
# 15059859 - License plate bracket
All in all, I think it would be a challenging--but VERY rewarding--swap. Good luck with it!
JordanH
Feb 28, 2017 07:22 PM
5.3Caprice
Nov 7, 2015 08:56 PM
thunder550
Oct 8, 2015 04:53 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
