20 x 10 SS wheels
Old Sep 14, 2010 | 07:58 PM
Default 20 x 10 SS wheels
20 x 8 SS wheels have a 5.5 back spacing. According to my measurement, a 20 x 10 with 7.5 in of back spacing would be within 1 inch of the leaf spring. I would like to run a 305/35/20. Anyone done this? Would clearance from the bed be a concern when the axle articulates? I have a 4/6 drop.
Old Sep 14, 2010 | 08:32 PM
WorkTruc's Avatar
I run a 7"' backset on my 20x15 without a problem.I have 1" of clearance from tire bulge which you have to take into consideration.If you do violent donuts or something like that you may have sidewall contact if you run 71/2" of backset.
Your bed tubs will have plenty of clearance with no concern.
Old Sep 14, 2010 | 09:35 PM
Thanks, sounds like I should try it. Measure twice, buy new wheels once.
Old Sep 14, 2010 | 09:47 PM
Where did you get the 20x10 from?
Old Sep 15, 2010 | 02:59 PM
I am going to have a set widened.
Old Sep 16, 2010 | 01:36 AM
xx_ED_xx's Avatar
if you would email me pic of your truck? Is yours a stock quadrasteer truck or did you swap beds?
edward.coss@gmail.com
Old Sep 16, 2010 | 04:29 PM
WorkTruc's Avatar
swapped beds
Old Sep 16, 2010 | 08:45 PM
WorkTruc - I have to admit, that is a mean looking set up you have. I saw your original thread as I lurk on here a lot.
Old Sep 16, 2010 | 09:30 PM
double047's Avatar
14 Second Truck Club
I am doing something very similar to my rear wheels, they are Texas Edition Stock 20x8.5 with 31mm offset and I will be running 305/50/20s with a 3/5 drop.
I am planning to have them widened by 1.5" to make them 10" wide.
Right now my rims are exactly 3" from my leaf springs so if i widen them by 1.5" on the Inside/Rear of the wheel then they should be 1.5" from the leaf spring.
Old Apr 21, 2021 | 01:47 AM
Digmt's Avatar
Registered User
Default ? On tire and wheel setup
admin won't let me PM you could you please PM me i had a couple questions about your build.
Probably cause im new and don't have enough posts yet?
denalircsb
Dec 21, 2020 09:04 AM
sprayed99
Sep 21, 2015 04:47 PM
George C....
Sep 11, 2015 04:45 PM
dselby25
Sep 11, 2015 05:03 AM
the owl
Sep 4, 2015 04:09 PM
