2" shackles=no drop at all WTF????
Old Feb 19, 2004 | 01:00 PM
pirate3's Avatar
Default 2" shackles=no drop at all WTF????
I just put 2" shackles on my SS Silverado with absolutley no differrence in height. What am I missing?????
Old Feb 19, 2004 | 01:18 PM
That doesnt make sense, maybe you got the wrong shackles, Did you make sure they were about 4" longer than the stock shackles??
Old Feb 19, 2004 | 01:27 PM
did you tighten the shackle bolt with the rear end up in the air
set it back on the ground
bounce the rear end couple of times
after loosening the shackle bolts
might have the rear shackles in a bind
not letting the rear end come down
Old Feb 19, 2004 | 01:43 PM
renegade4e's Avatar
14 Second Truck Club
put the bolt in the right hole? i made that mistake and it still looked stock.
Old Feb 19, 2004 | 02:15 PM
pirate3's Avatar
I'll try that.
pirate3's Avatar
Yep. Put in the furthest hole available. I used the belltech 6400's
Old Feb 19, 2004 | 02:38 PM
Originally Posted by pirate3
I'll try that.
any susp work - need to install with the hardward loose
settle the suspension
then tighten all the bolts
beat the rear shackle is bound up
dont want to overtighten the shackle either...
hope this helps
GMCtrk
Jan 27, 2016 06:47 PM
FlyingLow
Nov 24, 2015 10:05 AM
twake_410
Sep 25, 2015 10:09 PM
03chevytruck
Sep 14, 2015 09:15 PM
dhorner77
Sep 11, 2015 05:10 PM
