will chilled intake air help out?
Old Jul 26, 2011 | 11:16 AM
hvactech08's Avatar
Default will chilled intake air help out?
on my long drive to a job today i thought of the idea of refigerating the air coming into the intake by a means of a intercooler and dowtherm( liuqued that wont freeze till like -30. the idea is to sit the intercooler in a box of some sort that will aloow the intercooler tobecome very cold like 0 degrees. the question is will this make a bbig enough difference to fool with all the effort, if this has allready been done oon a N/A engine direct me to it, other wise let me know what yall think
Old Jul 26, 2011 | 12:40 PM
2007chevy5.3l's Avatar
I think to answer the basic question of will chilled iats help performance, yes. Going about doing that is all yours.
Old Jul 26, 2011 | 01:35 PM
philntx's Avatar
There's a 25 page thread on Camaro5forum on using the A/C system.
Drastically lowering IAT.... - Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com
Old Jul 26, 2011 | 01:36 PM
Atomic's Avatar
I have a gauge for that
Will it help, yes....but if you plan to use the AC system to chill the fluid then no, because the extra power required to turn the compressor will negate all gains from a cooler intake. You could try meth or water injection if you are concerned about really high temps (Which I wouldnt be NA).
Old Jul 26, 2011 | 01:57 PM
philntx's Avatar
Check out that read on the camaro forum. At WOT, the compressor is disconnected, so no loss. IAT's in the 100 degree range at the end of the run.
Old Jul 26, 2011 | 04:29 PM
hvactech08's Avatar
i was planing on using a intercooler and cirulating dowtherm or dow frost that i freeze in a deep freezer and then put it in a contator that is insulated very well and use a small pump to circulate it around the intercooler which i would build a conationer around it. hopin to get like 0-20 IATs
using very little energy from the power supply
Old Jul 26, 2011 | 10:48 PM
bighoss77's Avatar
too much work and b.s. for negligable gains IMO. why not go with nitrous? its really not all that expensive, just use it when you need it. go with a 50-75 shot and you'll be more than ok on a stock engine.
Old Jul 28, 2011 | 09:23 PM
rjwz28's Avatar
Man Motor club
It's an interesting idea. You should do it and post a build thread to keep us posted. Best of luck
Old Jul 28, 2011 | 09:25 PM
hvactech08's Avatar
my young mind gets these ideas, and usualy ends up costin me alot of money to inovate something new. all i need is a Air to water intercooler 4" pipe. let me know if any you guys got one you wanna sell
Corvette454l88
Sep 1, 2016 01:24 AM
GMCtrk
Dec 18, 2015 04:47 PM
The_W
Aug 18, 2015 04:57 PM
Ketis
Jul 23, 2015 12:37 PM
Suburban2500
Jul 14, 2015 02:10 AM
