Who likes diesel?
Old Oct 18, 2012 | 10:40 PM
  #91
TheGreat4.8's Avatar
This pig is all wired up finally but ran into an issue with the starter relay, apparently when i lopped off the transmission harness i also got the start wiring too because of the neutral safety dumb dumb switch , so it is now wired directly to the big yellow start wire on the key switch and works great no matter what gear I'm in haha.
still working on all the little stuff ie throttle linkage, narrowing the steering shaft, radiator mounting, tach sensor the list goes on and on
staying stock and non intercooled until i get all the bugs worked out, just trying to get it on the road again before i start hotrodding it...
Old Oct 19, 2012 | 12:21 AM
  #92
amanuel's Avatar
Awesome. Subd
Old Oct 19, 2012 | 03:45 AM
  #93
Spoolin's Avatar
GFYS and STFU
Very cool!!
How much you plan on narrowing the steering shaft? Sounds a bit dangerous.
Old Oct 20, 2012 | 02:35 PM
  #94
Originally Posted by Spoolin
Very cool!!
Not at all ill get some pictures if you want when it's finished.
the stock crush shaft was rubbing the engine cradle a little bit
Old Nov 2, 2012 | 04:20 PM
  #95
Very cool!!
Size:  102.4 KB machined ends and tig welded to a solid shaft
Old Nov 2, 2012 | 04:25 PM
  #96
got this beast painted up since this picture, getting it mounted and shimmed under the rig as of now Name:  P1010014.jpg
this was machined just for the crank reluctor ring
Got to make mount for the sensor... Name:  P1010022.jpg
Old Nov 3, 2012 | 03:24 AM
  #97
xXxSilveradoxXx's Avatar
Originally Posted by TheGreat4.8
You ground off the Dodge Ram from the charge pipe!
Old Nov 4, 2012 | 12:30 PM
  #98
Hell yea i did
Old Nov 4, 2012 | 06:04 PM
  #99
need my cross over steering tubing yet
Old Nov 5, 2012 | 06:56 AM
  #100
tiffo60's Avatar
Looks like its coming together nicely!!
