Well here we go again...
Old May 21, 2009 | 12:15 AM
  #171
Wilde Racing's Avatar
How do I change this text
WHERE are the PICS? (Nice converter BTW)
Old May 21, 2009 | 09:57 AM
  #172
silver-mod-o's Avatar
Hunt&Fisherator
Old May 21, 2009 | 01:07 PM
  #173
Dark Halo's Avatar
media blaster huh? I could use one of those in a very bad way. Do you want to trade converters? lol
Old May 21, 2009 | 05:12 PM
  #174
Hunt&Fisherator
Haha, you just need to send that thing back
My slip yoke showed up today too
Old May 23, 2009 | 07:46 PM
  #175
Hunt&Fisherator
Well I did a little final assembly on the motor today, and some things on the trans
Final install on the motor:
Turbo manifold
Stock driver side manifold
Turbo
Oil feed block/fittings/line
Modified PT billet turbo drain block
Drain hose and all fittings
Valve covers with new gaskets
New TR6 plugs
New Taylor wires
Coil packs
Fresh filter
Oil dipstick
Final assembly on the trans:
Cleaned entire case
Degreased/pressure washed pan
Fresh filter
New pan gasket
Front cooler line adapter fitting (for trans hose system)
As of right now the motor is 100% ready to sit in the truck, and I'm waiting on FLT to build my rear cooler line fitting. The only setback was me breaking the temp sensor off in the head got a new one on the way as well as 3 brand new U-joints, including the conversion U joint for the front yoke.
Still TONS of little stuff to do.
Old May 23, 2009 | 09:19 PM
  #176
GMCtrk's Avatar
hey did you see what supersub posted....he found the part numbers for 4l80e trans cooler hard lines that are a direct bolt up to the 1500 frame. I like the idea of everything being hard line'd
Old May 23, 2009 | 09:51 PM
  #177
Hunt&Fisherator
I like the fluid capacity and extra cooling of my -6 hose
And HATE those damn clips!!!
Old May 24, 2009 | 09:04 AM
  #178
GMCtrk's Avatar
you talking about the little e clips?
you ever see those things break and send the line shooting out?
Old May 24, 2009 | 09:11 AM
  #179
Hunt&Fisherator
Why yes, yes I have LOL, messy... I've found another route on the rear as far as a fitting too, we'll see how it works out.
Old May 24, 2009 | 05:49 PM
  #180
Duckslayer08's Avatar
